Groundsound DCN23 , DSP active crossovers
0 Members and 1 Guest are viewing this topic. Read 1265 times.
wagnju
« on: 8 Jul 2013, 03:05 pm »
For sale is a rarity on the US market . A stereo pair of Groundsound DCN23 DSP crossovers . Build your own speakers and switch them to an active system with these superb active crossovers and your choice of amps.
I bought them new from Groundsound for a speaker project that I never got time for and now these crossover jewels have to go .
I bought them as finished product  , not as a kit .  They have never been used and they are still in great condition .
Download the matching software from the Groundsound webpage and start your speaker project.
When you have questions , Robert from Groundsound is a great guy to deal with .
Dimensions are W9"xD6"xH2"
DCN23 is a high performance digital crossover filter with equalization and delay. It features 2 balanced analogue inputs and 3 single-ended analogue outputs (of which the third has an inverted output for easy bridging at e.g. low frequencies). The usage of high performance Burr-Brown converters gives DCN23 crystal clear sound and very low noise floor. The sample rate is 96 kHz to extend bandwidth and have low order analogue low pass output filtering. The resolution of converters is 24 bit and the internal signal processor resolution is 76 bit. The signal processor holds 3 channels of 16 biquads each for filtering and equalization. DCN23 has an optical isolated USB interface to avoid hum and noise from the PC.
The circuit board is a high quality 4 layer type which prevents noise and hum. The layout features a lot of decoupling - at supply entry and very close to all active components.
DCN23 is the heart of an active speaker management system offering a superb sound, easy installation and easy use in daily life.
http://www.groundsound.com/dcn23.php
http://www.groundsound.com/technical.php
http://www.groundsound.com/pdfdoc/Ground%20Sound%20-%20DCN23.pdf
asking price of $450 is for a pair ( two DCN23 units) and price is incl. shipping inside the conus US only via UPS ground .
Pickup in the Kansas City area is welcome too .
wagnju
Re: Groundsound DCN23 , DSP active crossovers
« Reply #1 on: 30 Jul 2013, 12:51 am »
end of July bump
