DSD - (Don't Stream Digital)
0 Members and 1 Guest are viewing this topic. Read 17045 times.
Phil A
Re: DSD - (Don't Stream Digital)
« Reply #20 on: 8 Jul 2013, 03:57 pm »
Here's an interesting summary of the recent Newport Beach show which goes over some of the items discussed in this thread - http://www.digitalaudioreview.net/2013/06/t-h-e-show-newport-beach-2013-dsd/
Phil A
« Reply #21 on: 8 Jul 2013, 04:06 pm »
Here's one comparison with a qualification:
http://www.audiostream.com/content/dsd-v-pcm-file-comparison-16441-2496-24192-64x-dsd-128x-dsd
“I admit that this could all be due to the Korg MR2000sBLK simply being better at converting to DSD and higher rate PCM as opposed to 16/44.1 or the Mytek DAC's ability to reproduce DSD over PCM. But I've also heard similar improvements with other recordings albeit under less controlled circumstances. My feeling is the differences noted between CD-"quality" and 24/192 and DSD are so marked as to suggest that the medium goes a long way in conveying the message.”
adprom
« Reply #22 on: 14 Jul 2013, 03:50 am »
When it comes to digital players, especially high end ones like the BDP-2, ideally they are format agnostic. The reason for this is, that you will have a range of buyers with different opinions. More than this, high quality music comes in a range of formats and the what the user is paying for is the ability to effectively stream any high res file, or decode it.
The role of a transport in modern audio with digital sources which have incredibly low jitter, even the cheap ones mixed with high quality DACs which have a decent quality FIFO buffer eliminates the transport as any meaningful influence on sound quality. It's job is to output the 1s and 0s accurately, preferably well within the specifications for jitter for what the DAC can handle.
As such, the value in high end streamers comes in their versatility and build quality. The value is in having something which is supported in the long term with updates to play the latest formats, which is of exceptional build quality and can play just about any format under the sun. Including the ability to output mp3s at 64k or DSD files at 352k. That is the differentiator.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #23 on: 19 Sep 2013, 12:00 am »
« Reply #24 on: 19 Sep 2013, 03:19 pm »
James,
I am not saying this chart is accurate, I Am reading that almost none of them stream Native DSD OUT...
https://docs.google.com/spreadsheet/ccc?key=0AgVhKcl_3lHfdFVyenBBNjNpQ2lieG81WGpqQTNfVUE#gid=0
So the real question is, and again this chart maybe wrong; Are any of the units that aren't licensed for DSD, really outputting DSD ?
It is like when I was at DENON and learned that CD ripping is NOT TRUE Bit for Bit, as everyone thinks because of the use of SCUMS   (Serial Copy Management), which is almost, but not quite allowing everything to pass.
Wayne
wisnon
« Reply #25 on: 19 Sep 2013, 03:32 pm »
The guys who only uise a LPF are streaming single bit.
I will just got one in for test that will do 128 and I hear its da bomb. Well let you know...
ted_b
« Reply #26 on: 19 Sep 2013, 03:53 pm »
James,
Wayne
I manage that "chart" and yes, it is as accurate as we know today.  Let me know if you think something is inaccurate, please.
Whoever Wayne is, he is either reading the database incorrectly and/or is not up on DSD terms like native vs DoP.  The "native DSD" nomenclature in the database is simply referring to ASIO playback (i.e NOT using the popular-but-nonetheless-still-pure-DSD DoP protocol).  In both cases, however, DoP or native, the outcome is indeed pure DSD format.    And his term "streaming" is  being used as a general term by this person (and many others).  Streaming is a usually, in this industry, a TCP/IP term, and involves packet handling, etc.  A USB DAC does not get it's data via streaming, it gets it via USB (or SPDIF, etc).   DACs are generally a digital input device (that output analog), and quite a few DACs don't output ANYTHING digitally, let alone DSD (so not sure what he means by "I Am reading that almost none of them stream Native DSD OUT...) .  but there are digital streamers that do output DSD (SBT with EDO, Lumin, Sonore, etc).  So not sure what his point is, really.
« Last Edit: 19 Sep 2013, 05:06 pm by ted_b »
bmoura
« Reply #27 on: 23 Sep 2013, 06:53 pm »
Looks like you're missing the exaSound e28 DSD DAC (up to DSD256 resolution) and the David Elias web site with Stereo and Multichannel DSD Downloads.  I'll send in an email with the links.
ted_b
« Reply #28 on: 23 Sep 2013, 07:59 pm »
Thx...got your email.  I'm sooo embarrassed that I missed doing the E28 as I'm the author of the CA review on the homepage!   :oops:
spinner
« Reply #29 on: 24 Sep 2013, 10:58 pm »
DSD hasn't done much to improve the remixes of those mono Stones and Beatles records. They were all in mono and nothing can repair that. :(
ted_b
« Reply #30 on: 25 Sep 2013, 12:18 am »
??  Beatles have never been DSD (but their mono PCM Sgt Pepper, White Album and Revolver , to name just three, are sublime IMHO).  The Stones in DSD are very good IMHO (esp Beggars Banquet and Let It Bleed).  And by the way, any format, be it PCM or DSD, is not intended to somehow improve remixes...they are not EQ's they are simply hirez formats.
redbook
  • the music is the blood...........
« Reply #31 on: 25 Sep 2013, 01:16 am »
  There isn't any "hi rez" on most of that poorly recorded mono 60's stuff. It's a shame things weren't done better then like jazz and classical recordings were. No amount  of dsd or remastering is going to really improve anything .  IMO :lol:
ted_b
« Reply #32 on: 25 Sep 2013, 01:23 am »
  There isn't any "hi rez" on those poorly recorded mono 60's stuff. It's a shame things weren't done better then like jazz and classical recordings were.
Steve Hoffman used to do seminars at CES (Venetian tower) and he'd bring out some special tapes only he had (a lot were things he was presently working on, like the NKC stuff).  One was a mono first master of the Beatles doing "I'm So Tired" from the White Album.  Not an outtake or Anthology piece; a real master copy version.  Holy Sh^T!  THAT was hirez, especially the amazing power of Paul's ultrasonic bass.  We need those 24/192 master they did for the remaster project...nevermind these dumbed down 44k versions.
« Reply #33 on: 15 Oct 2013, 01:00 pm »
« Reply #34 on: 15 Oct 2013, 01:00 pm »
« Reply #35 on: 16 Oct 2013, 05:09 pm »
Hi Folks,
In my office playing DSD Files on Chris's new Manic Moose BDP-2 Software
james
Marius
« Reply #36 on: 17 Oct 2013, 05:41 pm »
hi James,
What's your opinion now you've been playing these DSD files? Do or Dont stream Digital?
btw, when are we going to be able to testdrive the software... been a while since S1.73 2013-07-02 .....
Marius
Hi Folks,
james
« Reply #37 on: 26 Nov 2013, 06:13 pm »
INTERESTING ARTICLE on Digital Resolution:
http://www.dansdata.com/gz143.htm
james
« Reply #38 on: 27 Nov 2013, 12:31 am »
THE 16 BIT MYTH
It seems to me that there is a lot of misunderstanding regarding what bit depth is and how it works in digital audio. This misunderstanding exists not only in the consumer and audiophile worlds but also in some education establishments and even some professionals. This misunderstanding comes from supposition of how digital audio works rather than how it actually works. It's easy to see in a photograph the difference between a low bit depth image and one with a higher bit depth, so it's logical to suppose that higher bit depths in audio also means better quality. This supposition is further enforced by the fact that the term 'resolution' is often applied to bit depth and obviously more resolution means higher quality. So 24bit is Hi-Rez audio and 24bit contains more data, therefore higher resolution and better quality. All completely logical supposition but I'm afraid this supposition is not entirely in line with the actual facts of how digital audio works. I'll try to explain:
When recording, an Analogue to Digital Converter (ADC) reads the incoming analogue waveform and measures it so many times a second (1*). In the case of CD there are 44,100 measurements made per second (the sampling frequency). These measurements are stored in the digital domain in the form of computer bits. The more bits we use, the more accurately we can measure the analogue waveform. This is because each bit can only store two values (0 or 1), to get more values we do the same with bits as we do in normal counting. IE. Once we get to 9, we have to add another column (the tens column) and we can keep adding columns add infinitum for 100s, 1000s, 10000s, etc. The exact same is true for bits but because we only have two values per bit (rather than 10) we need more columns, each column (or additional bit) doubles the number of vaules we have available. IE. 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024 .... If these numbers appear a little familiar it is because all computer technology is based on bits so these numbers crop up all over the place. In the case of 16bit we have roughly 65,000 different values available. The problem is that an analogue waveform is constantly varying. No matter how many times a second we measure the waveform or how many bits we use to store the measurement, there are always going to be errors. These errors in quantifying the value of a constantly changing waveform are called quantisation errors. Quantisation errors are bad, they cause distortion in the waveform when we convert back to analogue and listen to it.
So far so good, what I've said until now would agree with the supposition of how digital audio works. I seem to have agreed that more bits = higher resolution. True, however, where the facts start to diverge from the supposition is in understanding the result of this higher resolution. Going back to what I said above, each time we increase the bit depth by one bit, we double the number of values we have available (EG. 4bit = 16 values, 5bit = 32 values). If we double the number of values, we halve the amount of quantisation errors. Still with me? Because now we come to the whole nub of the matter. There is in fact a perfect solution to quantisation errors which completely (100%) eliminates quantisation distortion, the process is called 'Dither' and is built into every ADC on the market.
Dither: Essentially during the conversion process a very small amount of white noise is added to the signal, this has the effect of completely randomising the quantisation errors. Randomisation in digital audio, once converted back to analogue is heard as pure white (un-correlated) noise. The result is that we have an absolutely perfect measurement of the waveform (2*) plus some noise. In other words, by dithering, all the measurement errors have been converted to noise. (3*).
Hopefully you're still with me, because we can now go on to precisely what happens with bit depth. Going back to the above, when we add a 'bit' of data we double the number of values available and therefore halve the number of quantisation errors. If we halve the number of quantisation errors, the result (after dithering) is a perfect waveform with halve the amount of noise. To phrase this using audio terminology, each extra bit of data moves the noise floor down by 6dB (half). We can turn this around and say that each bit of data provides 6dB of dynamic range (*4). Therefore 16bit x 6db = 96dB. This 96dB figure defines the dynamic range of CD. (24bit x 6dB = 144dB).
So, 24bit does add more 'resolution' compared to 16bit but this added resolution doesn't mean higher quality, it just means we can encode a larger dynamic range. This is the misunderstanding made by many. There are no extra magical properties, nothing which the science does not understand or cannot measure. The only difference between 16bit and 24bit is 48dB of dynamic range (8bits x 6dB = 48dB) and nothing else. This is not a question for interpretation or opinion, it is the provable, undisputed logical mathematics which underpins the very existence of digital audio.
So, can you actually hear any benefits of the larger (48dB) dynamic range offered by 24bit? Unfortunately, no you can't. The entire dynamic range of some types of music is sometimes less than 12dB. The recordings with the largest dynamic range tend to be symphony orchestra recordings but even these virtually never have a dynamic range greater than about 60dB. All of these are well inside the 96dB range of the humble CD. What is more, modern dithering techniques (see 3 below), perceptually enhance the dynamic range of CD by moving the quantisation noise out of the frequency band where our hearing is most sensitive. This gives a percievable dynamic range for CD up to 120dB (150dB in certain frequency bands).
You have to realise that when playing back a CD, the amplifier is usually set so that the quietest sounds on the CD can just be heard above the noise floor of the listening environment (sitting room or cans). So if the average noise floor for a sitting room is say 50dB (or 30dB for cans) then the dynamic range of the CD starts at this point and is capable of 96dB (at least) above the room noise floor. If the full dynamic range of a CD was actually used (on top of the noise floor), the home listener (if they had the equipment) would almost certainly cause themselves severe pain and permanent hearing damage. If this is the case with CD, what about 24bit Hi-Rez. If we were to use the full dynamic range of 24bit and a listener had the equipment to reproduce it all, there is a fair chance, depending on age and general health, that the listener would die instantly. The most fit would probably just go into coma for a few weeks and wake up totally deaf. I'm not joking or exaggerating here, think about it, 144dB + say 50dB for the room's noise floor. But 180dB is the figure often quoted for sound pressure levels powerful enough to kill and some people have been killed by 160dB. However, this is unlikely to happen in the real world as no DACs on the market can output the 144dB dynamic range of 24bit (so they are not true 24bit converters), almost no one has a speaker system capable of 144dB dynamic range and as said before, around 60dB is the most dynamic range you will find on a commercial recording.
So, if you accept the facts, why does 24bit audio even exist, what's the point of it? There are some useful application for 24bit when recording and mixing music. In fact, when mixing it's pretty much the norm now to use 48bit resolution. The reason it's useful is due to summing artefacts, multiple processing in series and mainly headroom. In other words, 24bit is very useful when recording and mixing but pointless for playback. Remember, even a recording with 60dB dynamic range is only using 10bits of data, the other 6bits on a CD are just noise. So, the difference in the real world between 16bit and 24bit is an extra 8bits of noise.
I know that some people are going to say this is all rubbish, and that “I can easily hear the difference between a 16bit commercial recording and a 24bit Hi-Rez version”. Unfortunately, you can't, it's not that you don't have the equipment or the ears, it is not humanly possible in theory or in practice under any conditions!! Not unless you can tell the difference between white noise and white noise that is well below the noise floor of your listening environment!! If you play a 24bit recording and then the same recording in 16bit and notice a difference, it is either because something has been 'done' to the 16bit recording, some inappropriate processing used or you are hearing a difference because you expect a difference.
1 = Actually these days the process of AD conversion is a little more complex, using oversampling (very high sampling frequencies) and only a handful of bits. Later in the conversion process this initial sampling is 'decimated' back to the required bit depth and sample rate.
2 = The concept of the perfect measurement or of recreating a waveform perfectly may seem like marketing hype. However, in this case it is not. It is in fact the fundamental tenet of the Nyquist-Shannon Sampling Theorem on which the very existence and invention of digital audio is based. From WIKI: “In essence the theorem shows that an analog signal that has been sampled can be perfectly reconstructed from the samples”. I know there will be some who will disagree with this idea, unfortunately, disagreement is NOT an option. This theorem hasn't been invented to explain how digital audio works, it's the other way around. Digital Audio was invented from the theorem, if you don't believe the theorem then you can't believe in digital audio either!!
3 = In actual fact these days there are a number of different types of dither used during the creation of a music product. Most are still based on the original TPDFs (triangular probability density function) but some are a little more 'intelligent' and re-distribute the resulting noise to less noticeable areas of the hearing spectrum. This is called noise-shaped dither.
4 = Dynamic range, is the range of volume between the noise floor and the maximum volume.
[/b]
*Scotty*
« Reply #39 on: 27 Nov 2013, 01:31 am »
James, do you have any idea at what point, as we descend away from 0dBFS in 16bit and 24bit systems we would hit 3% THD+N.
Scotty
