0 Members and 1 Guest are viewing this topic. Read 10075 times.
Also I was wondering if you were able to try and vertically stack your AE H frames. If so could you turn your lowther baffle sideways or make a new baffle to adjust the lowther's vertical height in relation to the new vertically stacked LF drivers?Visually it may look more appealing.I know you kept the LF drivers close to the floor to increase efficiency but your drivers have so much surface area it might not be necessary.
I would be a bit concerned in seeing all of your H-Frames being the same depth. Would you run into one big abrupt frequency change at the dipole cutoff frequency?I wonder how your system would sound if you had half of your H frames at a different depth. Would that help randomize the cutoff frequency roll off point more?I am not sure i am explaining this correctly as my knowledge is more limited. However I made the wings on the side of my baffle taper from bottom to top based on the Visaton NoBox BB Loudspeaker Kit review and article by Dick Olsher. It is on the Enjoy the Music website and it is very well written. It gives lots of tips on OB speakers.
I also borrowed some of my look and shape of my speakers based on the expensive Jamo R909 which has lots of interesting reviews in the internet especially the 6 Moons website article on them. I could just not pull off a passive crossover design so i cheated and used the DBX in a bi amp configuration with very good results.
Thank you very much for contributing SO much to the field of Open Baffle Loudspeakers.I am honored that a you would respond to my post.
I was also thinking that a vertical placement would change the amount of floor bounce artifact that may be present by changing the height of some of your LF drivers.I want to build another Open Baffle in the future a little like the Kef Blade concept that has all of the LF drivers mounted up higher away from any floors.I want to have the LF drivers work on their own merit not use a floor or wall or corner as a way to make them more efficient. I have a feeling that if I can get them to sound good away from any boundaries the bass will sound even better.
