Bryston Amp to BIT15 or Not?
0 Members and 1 Guest are viewing this topic. Read 1114 times.
Samurai7595
« on: 2 Jul 2013, 01:57 pm »
Can a Bryston 4B-SST2 power amp be connected to a BIT15 or would it be best to go directly to the power outlet?
budcook
Re: Bryston Amp to BIT15 or Not?
« Reply #1 on: 2 Jul 2013, 02:02 pm »
I just ordered a BIT15 under the assumption I could connect my 4BSST2 to it.  I am using a Cardas power cable which has built in noise filtering and Cardas told me it would simply add to what the BIT15 would do.
Bud
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 2 Jul 2013, 03:17 pm »
Yes you are OK with a 4B and a BIT 15.
james
