Signal cables silver resolution cables
0 Members and 1 Guest are viewing this topic. Read 1523 times.
Charles Calkins
« on: 19 Jul 2004, 05:50 pm »
Anybody try the Signal cable silver resolution cables?
          Charlie
Charles Calkins
signal cable silver resolution cable
« Reply #1 on: 23 Jul 2004, 10:55 pm »
Got mine today. I've been listening to it for about fours. It sounds just a tad better that Kimberkable silver streak interconnect.
« Reply #2 on: 28 Jul 2004, 10:08 am »
Charlie,
What equipment are you using with these interconnects?
Whats your musical preferences?
What led you to selecting these?
thanks
Charles Calkins
Signal cable silver resolutiom
« Reply #3 on: 28 Jul 2004, 03:20 pm »
JLM:
  I'm using a Conrad Johnson PFR solid state preamp. Two Nad 218THX amps. in mono mode.
 I listen to smooth jazz. Sometimes classical.
 Construction of cable was all silver.
            Cheers
           Charlie
Zero
« Reply #4 on: 28 Jul 2004, 07:01 pm »
Incredible cables  - I returned them only due to their inability to match well with my system.
Very fast, very bright.. great control.
Jon L
« Reply #5 on: 28 Jul 2004, 07:14 pm »
Quote from: A6M-ZERO
Huh?  "Very bright" and not a good match with your system (due to brightness? but they are still "incredible???
Zero
« Reply #6 on: 28 Jul 2004, 10:04 pm »
Jon,
The speakers I have can become rather foward if not  complemented well.  The signal silvers showed excellent resolution and the trademark of a good product. It simply did not go with my system well at all.
Great company, good product, 30 day trial period, not much to loose..
