Aftermarket Tonearm lifters
0 Members and 1 Guest are viewing this topic. Read 1618 times.
WireNut
« on: 29 Jun 2013, 07:09 pm »
  What aftermarket Tonearm lifter do you use and how do you like it  :?:
plastico
Re: Aftermarket Tonearm lifters
« Reply #1 on: 29 Jun 2013, 08:24 pm »
I got the Q-UP. I have this on my P3, and I love it. I got it to lift the arm with no bounce.  :nono:
Cheers, Plastico
SteveFord
« Reply #2 on: 29 Jun 2013, 08:31 pm »
Q-Up for me as well.
Stupidly overpriced for what it is and if you adjust the arm height you'll need to reset the Q-Up's height as well.
WireNut
« Reply #3 on: 29 Jun 2013, 08:53 pm »
Cheers, Plastico
Did you have to do anything special to stop the Q-Up from bouncing or did the adjustment level do the trick?
thunderbrick
  • I'm just not right!
« Reply #4 on: 29 Jun 2013, 09:18 pm »
Not sure if it is still on the market, but I used to have an Audio Technica AT-6006a tonearm lift and loved it!  Silky smooth and classy looking!    :thumb:
http://www.youtube.com/watch?v=2DEgRrRIV7A
plastico
« Reply #5 on: 29 Jun 2013, 09:27 pm »
I managed to do this with just the adjustment level, and it appears, an incredible amount of luck! And yes, after I installed my Riggle VTAF, I had to re-adjust the Q-Up`s height.
Cheers, Plastico
