Any strategies on how to network a Teac UD-501?
0 Members and 1 Guest are viewing this topic. Read 5789 times.
bachiano
« on: 27 Jun 2013, 09:08 pm »
Thinking of getting one of these so I thought I'd ask.
My first thought was a headless mac mini but if there are other options, I'd love to hear them.
Thanks in advance.
Bachiano
ted_b
Re: Any strategies on how to network a Teac UD-501?
« Reply #1 on: 27 Jun 2013, 09:31 pm »
The TEAC is not a network player.  It is simply a stand-alone DAC.  There is no network involved, and no network connections available; just hooking a digital cable from a transpor, or a  USB cable from PC/MAC to the unit.  All local, sorry.
Brad
« Reply #2 on: 27 Jun 2013, 09:36 pm »
Headless is the way to go for me.  PC running Windows Server 2k8R2, but I am looking at Windows Server 2012.
As Ted says, no other way to go.    Run preferably wired Ethernet to that location to the PC/MAC of your choice.
ted_b
« Reply #3 on: 27 Jun 2013, 09:41 pm »
I think, as an OS, that Windows Server 2012 (GUI edition) is a wonderfully musical one.  JRiver and Jplay (single pc to start, then dual pc to max it out).  Jremote ipad browsing.
bachiano
« Reply #4 on: 27 Jun 2013, 10:10 pm »
This is what I was considering.
Doing everything on the mac side.
I have a Mac mini, JRiver and JRemote
I can run the mac mini USB to Teac.
The mini is wirelessly connected to my network and to my hard drive that contains all my files.
JRiver serves.
JRemote controls from iPad and/or Screen Sharing Controls from my main mac.
Mac mini delivers via USB to the Teac.
If I get into trouble I can access the mini through my main mac with Screen Sharing or with one of the many VPNs available for the iPad.
What do you think?
ted_b
« Reply #5 on: 27 Jun 2013, 10:33 pm »
I would not do wireless access to music or Mini.  Wired only.  Wireless (rf, noise and limited bandwidth) has no place in a good music server environment (except for wireless iPad to router/LAN).
bachiano
« Reply #6 on: 27 Jun 2013, 10:39 pm »
Ok.
So running an Ethernet cable to the mini would work well?
I was trying to avoid that but for the love of art I guess I can sacrifice :-)
bachiano
« Reply #7 on: 27 Jun 2013, 10:59 pm »
Hi Ted
Just had a thought.
Do you think the Lumin Network Music Player is a compromise do to it being networked.
ted_b
« Reply #8 on: 27 Jun 2013, 11:05 pm »
Network is not a compromise.  And no...but it's a SEVEN TIMES the cost compared to your Teac ($5490 vs $799).   :o  At that price we can talk about MANY great DACS and a Windows server combo.
bachiano
« Reply #9 on: 27 Jun 2013, 11:19 pm »
Wow - I did not realized it was that expensive.
I definitely cannot get into that price range.
So will an ethernet cable suffice for me, considering my measly capital?
bachiano
« Reply #10 on: 28 Jun 2013, 05:07 pm »
Silly me.
I don't need and ethernet cable at all.
I'll just put the external drive with all my files next to the mac mini :-)
Brad
« Reply #11 on: 28 Jun 2013, 05:17 pm »
If you're going to remote control the mac mini from another device, you'll need some way to connect to it, won't you?
ted_b
« Reply #12 on: 28 Jun 2013, 05:18 pm »
Silly me.
That doesn't remove the need to wire up the Mini to the LAN.
bachiano
« Reply #13 on: 28 Jun 2013, 06:33 pm »
I'm Sorry Ted, that went over my head.
Why do I need to connect the mini to LAN?
The External Drive will be hardwired to the Mini.
The Mini will have JRiver installed and will be hardwired to the Teac.
The mini has wifi so I can control JRiver with JRemote.
What am I missing?
srb
« Reply #14 on: 28 Jun 2013, 06:56 pm »
The mini has wifi so I can control JRiver with JRemote.  What am I missing?
Nothing, really.  While it's more common to communicate wirelessly with a Mac through a separate wireless router, you can create a network on your Mac and it becomes the router.  Many do this on their Macbooks and switch to that network when traveling to be able to use smartphone remote apps without an external router.
Brad
« Reply #15 on: 28 Jun 2013, 07:16 pm »
I'm with Ted on this one.  I think the hardwired Ethernet has much less potential for noise/interference.
bachiano
« Reply #16 on: 28 Jun 2013, 07:17 pm »
Steve.
That's what I was thinking.
I just tested both methods and they both work well.
bachiano
« Reply #17 on: 28 Jun 2013, 07:22 pm »
Look at my device chain.
Everything will be hardwired from my files to the Teac.
The only thing that is wireless is the controller.
Brad
« Reply #18 on: 28 Jun 2013, 07:47 pm »
The mini itself will be transmitting to the network via wifi
bachiano
« Reply #19 on: 28 Jun 2013, 08:20 pm »
I still don't get it.
How does "transmitting to the network via wifi" negatively affect a hardwired device chain?
In any case how am I going to use the controller without wifi ???
