Anybody using Slim Server 7.2.2
0 Members and 1 Guest are viewing this topic. Read 2173 times.
pmarun
« on: 26 Jun 2013, 12:02 pm »
Hello All
I downloaded and installed Slim Server from the Logitech squeezebox site.
Now the formatting - meaning the layout of the screens are all gone. When I select An Album and select it track to play it just goes on to give more details of the track and am not able to play from the web control. Anybody using Slim Server the latest version 7.2.2.
I am using SB2 and it is painful to navigate using the remote.
Bob in St. Louis
Re: Anybody using Slim Server 7.2.2
« Reply #1 on: 26 Jun 2013, 09:38 pm »
I quit using the "factory" software altogether. I'm using "Orange Squeeze" and controlling it via my Android device.
Hopefully that's helpful??
pmarun
« Reply #2 on: 28 Jun 2013, 09:21 am »
Thanks Bob. I have to try that. Looks like not getting away from the server sw itself which is installed on my laptop. I stopped using it for general purpose and was beginning to use it as a dedicated server for my squeezebox.
I have had it for a couple of years now and there is always one issue or the other popping up. Now it could be becaus eof my ignorance also. Just goes to say PoP that disc in and enjoy your music.
Will keep trying though  :duh:
DanH
« Reply #3 on: 28 Jun 2013, 03:23 pm »
I am running 7.7.2. Over the years I have had a couple of instances where thing went a little odd after a version upgrade. You may have done this already but I found that uninstalling LMS and re-installing it usually cleared things up. Once I had to delete the squeezebox directory after the uninstall also.
mca
« Reply #4 on: 28 Jun 2013, 04:49 pm »
Bob,
Tell us more about Orange Squeeze please!
Bob in St. Louis
« Reply #5 on: 28 Jun 2013, 05:06 pm »
Bob,
Sure, I LOVE IT:thumb:
They have a free version >HERE<, and a $2.99 version >HERE<.
These are for Android, I have no experience with Apple versions.
It's a great program, I highly recommend it. I've had some source issues (not related to "Squeeze"), so my system has been inoperable for some time now. I had just gotten good at using the interface when things went down, so I can't get too specific with questions about Orange Squeeze. However, I liked it much more than the Squeeze Commander (or whatever the factory app is called).
Hope that helps,
Bob
mcgsxr
« Reply #6 on: 28 Jun 2013, 05:58 pm »
I am using 7.2.2 now.  It is loaded on a netbook, with 2TB of FLAC attached.
I no longer own any Slim devices, but use a hacked Pogoplug as my player.
I use iPeng on an iTouch to control the server.
Been running trouble free since I set it up around 6 weeks ago.
mitch stl
« Reply #7 on: 28 Jun 2013, 08:28 pm »
I tried both Orange Squeeze and Squeeze Commander and much prefer the latter. I mainly use my Kindle Fire with Squeeze Commander for controlling my Squeezeboxes (2 Touches, 1 SB3 and a Radio). Can't help with the 7.2.2 version. I use the latest Vortexbox OS which runs LMS and have zero problems.
JEaton
« Reply #8 on: 28 Jun 2013, 11:01 pm »
Do you actually mean version 7.7.2 of what is now called "Logitech Media Server"?
http://www.mysqueezebox.com/download
Personally, I'd run the latest of LMS 7.8 instead:
http://downloads.slimdevices.com/nightly/index.php?ver=7.8
Where has your screen formatting changed? On the Squeezebox 2, when you use the remote?
golfugh
  • Dead Can Dance - Into the Labyrinth
« Reply #9 on: 28 Jun 2013, 11:21 pm »
Running 7.7.2 with no issues, LMS and Touch.  Try to delete the whole thing and reload.  Then clear the cache and see what you have.
If you were using a previous version there is only classic now for formatting/background.
golfugh
« Reply #10 on: 28 Jun 2013, 11:23 pm »
JEaton, what is good with 7.8?
Mark
JEaton
« Reply #11 on: 28 Jun 2013, 11:33 pm »
Not a lot of difference. Mostly bug fixes, plus a small change that I mention here.
golfugh
« Reply #12 on: 28 Jun 2013, 11:42 pm »
