Bob Carver BLACK BEAUTY 305 ( VTA305M ) 220-240 voltage 3 months Old
0 Members and 1 Guest are viewing this topic. Read 1807 times.
Dragon_vibe
Selling My Pair of Bob Carver 305, Less them 3 months old. 220-240 Voltage Asking price is 7000.00 US Offers will be accepted depending on payment method. No low ball offers pls. Its already a big loss considering the price that was paid for these brand new.
I can ship this to anywhere in the world except Russia. Payment by Bank Wire. Warranty is Transferable. Condition is A+ no Dents scratches or noise. It just works perfectly.
305 Watt Mono Block Amplifier
The Black Beauty 305 Mono Block Amplifier is the perfect blend of form and function and the ideal choice for serious music listeners. This amplifier was designed to drive the most demanding speakers and features a high impedance input, an automatic DC restorer circuit, a "set and forget" bias adjustment, and low idle current which greatly increases output tube life. It has an ultra-wide bandwidth output transformers with interleaved windings capable of the most nuanced voice as well as huge peak output capacity. Selectable feedback control allows the user to change the sound of the amplifier from vintage classical to modern contemporary.
Our amplifiers are available in either Cherry or Black and in 120 volts or 220-240 volts.
SPECIFICATIONS
Number of Line Inputs: 1
Input impedance: 100 k ohms
Input Stage: 12AX7 current sourced low noise valve
Pre-driver Stage: 12AT7 long tailed high gain balanced pair
Automatic DC Restoration: 6AL5
Nominal Voltage Gain: 30 dB (into 8 ohms)
Output Stage Configuration: 3 complementary Sets of KT120s in a push pull configuration (6 total)
Regulated Screen Supply Voltage: 390V
Output tube plate voltage: 785V
Output Tube Idle Power: Less than 14W each
Bias Adjustment: Rear panel pot, front panel meter, "Set and Forget"
Rated Power: 305 watts into 8 ohms, 330 watts into four ohms, 290 watts into two ohms
Noise: Better than 110 dB A Weighted referenced into 305 watts
Hum: -100 dB
Frequency Response: 2 Hz to 85 kHz. (-3dB)
Full Power Bandwidth: 24 Hz to 28 kHz. Without filters
Feedback Control Switch: 20dB for Classic Amplifier Sound, 11 dB for Contemporary Amplifier Sound
Distortion: Less than 0.5%
Output Transformer: Interleaved windings, super wideband low leakage inductance design
Output Impedance: 1.6 ohms
Speaker outputs: 2, 4, and 8 ohm terminals
Built in Output Tube Tester: Yes
Construction Method: Point-to-Point hand wired axial and radial leaded components with star grounds and no circuit board traces or de-plugable connectors.
Components: High reliability wire wound and metal film resistors, Metal polyester capacitors in the audio signal paths
Weight: 43 lbs per chassis
Dimensions: 14" deep x 12" wide x 7.2" tall
Color: Gloss Black with a silver fleck and brushed silver trim is standard or optional Cherry Red with Champagne colored trim.
Country of Origin: United States of America
Warranty: Chassis - 7 Years, Tubes - 1 Year
« Last Edit: 26 Jun 2013, 06:16 pm by Dragon_vibe »
