Phono stage of Tempest
0 Members and 1 Guest are viewing this topic. Read 2034 times.
Farmer
« on: 11 Feb 2003, 04:21 pm »
Hi, Does anyboy know what is the gain (in db) of this preamplifier?  I like to try a moving coil cartridge but I am not sure what type (low, medium, or hight output) I should use to match the Tempest.  I could not find it in the user manual.  My system is Strato, Tempest and MMF-5.
Thanks in advance for your opinion.
Brad
« Reply #1 on: 11 Feb 2003, 08:48 pm »
From what I recall of my Tempest, it had an mm/mc switch and was spec'd for high output mc or mm.
The Dynavector 10x4 is supposed to be a good match for the MMF-5.
