bass trap question
0 Members and 1 Guest are viewing this topic. Read 2406 times.
coxhaus
bass trap question
« on: 25 Jun 2013, 04:03 am »
How would you compare 4 tri-traps against 2 soffit trap? I need to buy some bass traps. Do you think they work better in the front or back?
Alex Reynolds
  • Bringing Your Sound to Life
    • GIK Acoustics
Re: bass trap question
« Reply #1 on: 26 Jun 2013, 02:48 am »
It depends on what area you're trying to absorb. If you're looking to do under 60 Hz I would probably recommend the soffit traps. But 70 Hz and above the four TriTraps would be much more effective.
The amount of reduction you get from the front or back depends on the room - sometimes one in each corner is best. I do recommend trying the different combinations (they are freestanding so aren't difficult to re-position. We usually recommend trying them on the front wall first as it helps cut down on some of the flutter echo and other high frequency problems in the front of the room a bit.
