blu ray audio only 48khz/24bit??
0 Members and 1 Guest are viewing this topic. Read 2233 times.
alexone
« on: 21 Jun 2013, 08:51 pm »
hi, guys!
i just purchased Rolling Stones "GRRRR" album (blu ray audio). my Bryston BDA-1 dac tells me that it is just 48khz (cannot see the incoming 'bit' but i assume it is 24 bit). the disc should give a PCM 96/24 output signal as far as i understand the specs...
anyone knows what is going on? could it be some kind of copyright things that doesn't allow to get a 96khz signal from the disc?
thanks,
al.
ted_b
Re: blu ray audio only 48khz/24bit??
« Reply #1 on: 21 Jun 2013, 09:18 pm »
This must be BluRay misconception day!  Sorry, but this is the third question like this about BluRay connections today!
BluRay audio is limited to 48k via coax/toslink (i.e to your Bryston DAC).  Period.  Always has been.  If you want more than that (like the LPCM 24/96 layer) then go HDMI and de-embed it with an HDMI de-embedder solution I wrote about 3 years ago this month:
http://www.audiocircle.com/index.php?topic=82217.0
or rip the BluRay to your hard drive
http://www.computeraudiophile.com/content/473-ripping-blu-ray-easy-way/
rbbert
« Reply #2 on: 21 Jun 2013, 11:11 pm »
I don't for sure about the Stones Bluray in the OP, but as Ted knows a huge number of music Blurays DO have only 24/48 audio, although it is sometimes in a 24/96 "shell".  Fortunately for us, more and more Blurays are being released with true 24/96 or 24/192 sound.
Regardless, though, you're only going to get 16/48 from a Bluray through S/PDIF.
alexone
« Reply #3 on: 22 Jun 2013, 03:46 am »
...ok, thanks ted & rbbert :D
al.
