Cornet resistors 370 Tranny
0 Members and 1 Guest are viewing this topic. Read 1338 times.
Rono944
« on: 17 Jul 2004, 06:50 pm »
Hi, I too had a failure with a 270BX tranny.  I ordered a 370BX along with new resistors as per Jim's post.  With the board removed I was wondering;
1.  If I should change the resistors for the constant current source from 1k to 910 Ohm as now specified.
2.  Is it okay to use a 1.5KV, poly capacitor for C9 or does it have to be and AC rated cap.
Thanks in advance,
Ron
hagtech
« Reply #1 on: 19 Jul 2004, 11:14 pm »
The 1k to 910 value change is not that critical in the current source.  Yes, any cap voltage rating above what is needed in circuit is fine.  C9 does not need to be safety rated as it is on secondary.  Not so for C20.
jh :)
