Hum From BP6
0 Members and 1 Guest are viewing this topic. Read 1182 times.
XKevinX
Hum From BP6
« on: 18 Jun 2013, 11:06 pm »
I have noticed a hum that I suspect is from my BP6.  With all sources off and my 3BSST on, there is a hum.  It is not attenuator influenced. If I turn off the BP6, leave the power amp on, the hum disappears.
Any ideas or suggestions to eliminate this noise?
Kevin
  • The Demo is Everything!
    • http://www.bryston.com
Re: Hum From BP6
« Reply #1 on: 19 Jun 2013, 01:33 am »
Kevin
Hi Kevin
Try floating the ground on the preamp power plug.
james
XKevinX
Re: Hum From BP6
« Reply #2 on: 20 Jun 2013, 01:43 am »
Thanks James. Can you explain what it means to float the ground on the power plug. Thanks.
K
srb
Re: Hum From BP6
« Reply #3 on: 20 Jun 2013, 01:50 am »
I think he means to try a grounding "cheater plug" adapter to see if the hum disappears with the ground disconnected as a troubleshooting tool.
XKevinX
Re: Hum From BP6
« Reply #4 on: 20 Jun 2013, 02:26 am »
Makes sense..
