FS: 1 Oyaide R-1 Outlet Great condition.
0 Members and 1 Guest are viewing this topic. Read 686 times.
Berto
« on: 18 Jun 2013, 05:47 pm »
Selling one barely used Oyaide R-1 outlet in great condition.
Retails for $170 plus shipping. Will sell for $85 including free shipping in con USA and gift paypal, otherwise add 3%.
OYAIDE R-1 Power Supply Outlet
The supreme wall outlet.
In order to respond adequately to the demands of customers, it has taken many years to make researches, test repeatedly, and achieve to produce the innovative product. Consequently, Oyaide now can introduce the R-1 as the advanced model of SWO-ULTIMO SERIES.
The contact of the R-1 is made of beryllium copper that insures mechanical integrity and high conductivity and also reduces vibration at the point of contact with no loss of signal transmission.
The plating of the R-1 is a combination of platinum and palladium which was selected as a result of repeated listening tests.
The housing of the R-1 is made of 30% glass filled PBT because of its excellent machining characteristic and electrical isolation. Its rating capacity is 20 amps.
The R1 outlet was designed with the same uncompromising concept as our flagship models F1 and M1 connectors.
Specification
* Blade: Beryllium copper (20A)
* Plate: Two times of grinding processes. Platinum(0.5layer Micron) layer Paradium(0.3 Micron)
* Case: High rigidity, Glass filler(30%), Polybutylene terephthalate
* Mount frame: Brass(24K plating)
* wire gage: max AWG10(5.5sq)
* vol/amp: 125V/15A 20A E Recognition
