Question about BIT Conditioners
0 Members and 1 Guest are viewing this topic. Read 1150 times.
budcook
« on: 18 Jun 2013, 03:25 pm »
This may be a rather dumb question (nothing new from me) but would it a make any sense (or nonsense) to plug my 4BSST2 with a Cardas Clear power cable into a BIT 15?  The Cardas cable has built-in toroidal filters.
My other option is to get a BIT 5 for my front end components and plug the amp into the wall outlet.
I live in Arizona so lightning hasn't been much of a problem since we moved here.  In other words surge protection isn't too important to me.
Bud
werd
Re: Question about BIT Conditioners
« Reply #1 on: 18 Jun 2013, 04:23 pm »
Here is some good advice.  Go for the bit 20 in 240. Have an electrician come in and put a 240 outlet in.  I used the 4Bsq into a rm 20 and it lit right up. The amp comes alive.  Plug everthing into it.
budcook
« Reply #2 on: 18 Jun 2013, 09:04 pm »
I just bought a Cardas Clear power cable with that toroidal setup in it.  The question I have is would it make a difference one way or another if I plugged the cable into a BIT?
Did you replace the cable on your rm 20 with something different?
Bud
budcook
« Reply #3 on: 18 Jun 2013, 10:20 pm »
Never mind, Brian at Cardas answered my question.  The cable supplements the BIT.
Bud
robb
« Reply #4 on: 20 Jun 2013, 01:59 am »
Hi  I am confused. Does Cardas specifically design a power cable for the BIT?
budcook
« Reply #5 on: 20 Jun 2013, 02:06 am »
No, Cardas power cables have broad band filtering which uses a built-in toroidal filter.  I was wondering if this made any difference it I plugged the cable into a BIT which also does filtering.
Cardas told me it only adds to what the BIT does.
