Anyone have engineering dimensions of a Betsy
0 Members and 1 Guest are viewing this topic. Read 2097 times.
sjalloq
« on: 18 Jun 2013, 11:26 am »
I'm trying to find some dimensions of the basket and mounting holes in order to cut my baffle.  Anyone have any dimensions they have successfully used?
Thanks.
JohnR
Re: Anyone have engineering dimensions of a Betsy
« Reply #1 on: 18 Jun 2013, 11:37 am »
 :scratch: Ask Paul...?
sjalloq
« Reply #2 on: 18 Jun 2013, 12:01 pm »
He was unresponsive...  :scratch:
zipidachimp
« Reply #3 on: 20 Jun 2013, 09:23 pm »
inner hole 71/4", outer hole 81/4" , inset 3/16".  mine will probably end up as either a 2-way or 3-way, 2-way if the sound is ok or mids in a 3-way.
sjalloq
« Reply #4 on: 23 Jun 2013, 05:27 pm »
 :thumb:  Thanks a lot.
