Deqx hdp-3 any experience
0 Members and 1 Guest are viewing this topic. Read 3701 times.
this_is_vv
« on: 17 Jun 2013, 07:41 pm »
so just bought the HDP-3 atlast....any one have any experience with it . Need to do all the measurement etc with it...
will be used as preamp,dac and 3 way XO ....too much to ask :D
V
JohnR
Re: Deqx hdp-3 any experience
« Reply #1 on: 18 Jun 2013, 08:38 am »
A few people are/have used it. This might help: http://www.audiocircle.com/index.php?topic=77634.0
I've set mine up as a single in-out only so far and will be trying to get it running properly as a 3-way soon. The systems I've heard that use it properly have sounded really, really good.
this_is_vv
« Reply #2 on: 19 Jun 2013, 02:37 pm »
Yes John ,
I heard the same review around....i have to make it use as 3 way DAC and preamp as i am selling everything to fund this...and i heard there is lot of learning needed for this....thought anyone have taken a chance on this...
V
this_is_vv
« Reply #3 on: 21 Jun 2013, 01:34 pm »
And the DEQX is here...now lets see how it will mate with a NCore etc
this_is_vv
« Reply #4 on: 28 Jun 2013, 11:44 pm »
my PCs are not seeing the DEQx....tried 2 different pcs,...under the device manager it says drivers not found....i am using windows 7...any help or drivers please....
YoungDave
« Reply #5 on: 29 Jun 2013, 12:27 am »
I am using the HDP-3 Deqx.  I use it as an active crossover for my 3-way speakers. I removed the passive crossovers from my speakers and installed 3 sets of binding posts, 1 each for woofers, mids, and tweets, direct connection from the posts to the drivers.  I also use the speaker correction functions, including correction of the response delay of the different drivers, and I also use the room correction function.  I do not use it for a preamp as my Steelhead handles that, and I do not use the deqx as a dac - just as a smart crossover and room correction device.
I changed my VMPS RM40 speakers to active tri-amp some 5 years ago or more, originally using an active crossover from David White of the now-defunct White Noise Audio.  The improvement was enormous and I will never allow passive crossover components into any of my speakers again!  Moving from the White Noise straight analog crossover (of excellent design) to the digital crossover and other DSP solutions of the DEQX was another giant step forward.
Re your problem with your computer recognizing the deqx, I also use Win 7 and have no problems in that area.  I do recall some discussion about drivers on the Deqx beta users group, one of the yahoo groups.  That group does not seem to be active right now but the deqx Website might have more info.  I seem to recall that new drivers were needed for 64-bit Win 7, which I have, and they work fine for me.  I am using DEQX 2.70; if you need it, it is available on the Deqx site www.deqx.com/upgrades.php or you could PM me.  It might have the drivers embedded.  It has been a year or two since I installed it on my computer and I do not recall all the details, except that the install went smoothly but definitely required a driver package.  I seem to recall that the 64-bit driver package was a self-extracting installation done first, and then the 2.70 package was installed, but I might misremember that.
Good luck - it is well worth the effort.
this_is_vv
« Reply #6 on: 29 Jun 2013, 01:20 am »
thank you that solved the problem....2.7 was the key.....
V
this_is_vv
« Reply #7 on: 1 Jul 2013, 01:48 pm »
Need help...
So i am doing measuring the speaker...i moved the HDp3 for some reason and inside i see a capacitor is not glued at all and moving in all direction wherever i told the HDP3...it seems to work fine for measuring etc....
talked to the guy he said u can glue it and it will be fine...
i am kinda worried spending some real hard cash and getting this...worth it???
V
this_is_vv
« Reply #8 on: 12 Jul 2013, 01:48 pm »
Anyone have any experience in opening up the HDP3. In my HDP3 there are large capacitors . One of them is loose and it moves around when i move the HDP3. I asked the DEQX supprt and they say there should be no capacitor and it seems this is modified HDP3.
Any one have any idea about it???
V
JohnR
« Reply #9 on: 16 Jul 2013, 08:06 am »
Hm  :scratch: Perhaps a photo would help? ;)
