Any Way to Make BDP-2 Plug and Play?
0 Members and 1 Guest are viewing this topic. Read 5234 times.
budcook
Re: Any Way to Make BDP-2 Plug and Play?
« Reply #20 on: 19 Jun 2013, 03:19 am »
Here are a couple more options.  Had I noticed these first, I would have bought them in lieu of the precision screwdriver.
A great multi-bit screwdriver that should handle any job.
http://www.homedepot.com/p/Klein-Tools-Magnetic-Screwdriver-with-32-Bit-Set-32510/100648026#.UcEe1JzNnsI
If you have a full size handle, but need the bits.
http://www.homedepot.com/p/Klein-Tools-32-Piece-Tamperproof-Bit-Set-32525/100647923?keyword=32525#.UcEg-5zNnsI
Personally, I would get the one with the handle for the extra $7.45.
I hope this helps.
It does help.  I want something like that with a big handle and good quality.  I'll check it out.
Bud
