Where did this panasonic receiver come from?
0 Members and 1 Guest are viewing this topic. Read 2034 times.
cjr888
« on: 16 Jul 2004, 10:24 pm »
If this has been mentioned plenty in the past, just mention, but I'd never heard of the Panasonic SA-HE200K until now, and it appears to be a digital amplifier as well....but in a much larger chassis (more mod friendly?), available at $288, support for 24/192 on 2 channel, 'multi-source re-master', dynamic range of 122db and marketing speak that states "unlike panasonic's conventoinal receivers which use input volume to "squeeze" the audio signal before amplification, the SAHE200k HQ Sound Mode uses a system that varies the actual gain of the amplifier.  This helps provide clear reproduction of the re-mastered music signal for more subtle imaging when listening at regular volume levels."
http://www.vanns.com/shop/servlet/item/features/538388710
I didn't see it listed here:
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelList?storeId=11251&catalogId=11005&catGroupId=11135
Is this a digital amplifier?
newtopos
« Reply #1 on: 16 Jul 2004, 10:55 pm »
Not digital, according to this website:
http://www.videodirect.com/panasonic/receivers/compare.html
I'll defer to those more knowledgeable, though, if I'm mistaken.
cjr888
« Reply #2 on: 16 Jul 2004, 11:10 pm »
Rats.  Oh well.  Apologies.
Neild
« Reply #3 on: 30 Jul 2004, 07:19 am »
That site looks to contain a fair number of errors.  This looks like somebody cut & pasted the SA-XR70 specs in for the HE200.
In the large picture you can see a "MOSFET" label which I believe will tell you this not a digital amp.
