two steps to the hangman instead of 13
0 Members and 1 Guest are viewing this topic. Read 1888 times.
drummermitchell
« on: 14 Jun 2013, 05:29 pm »
I found a real easy way to hang traps instead of using wire,slots ect.
Maybe some of you know about these,they are based off of the french cleat.
I have seen people make them out of wood ect.
These are off of Amazon.com and are called EZ-ancor Hangman.
I use these with the Q7D's and the soffit traps.they hold up to 200lbs and sizes vary.
They come with a small level you insert in the middle which you can slide across the cleat.
I found when I tried these it was a breeze to install instead of wire and the slot system and these are dirt cheap:
best pict I could find,but on Amazon or a search will reveal better picts.
Alex Reynolds
  • Bringing Your Sound to Life
    • GIK Acoustics
Re: two steps to the hangman instead of 13
« Reply #1 on: 18 Jun 2013, 07:19 am »
Yes, these types of hangers are known as "French Cleats"
They do make hanging very easy! A lot of people are reluctant though as they cause more damage to the walls than a single Ooks hook does. They hold on really well.
