Audio/Video Gear and Systems
Headphone Mania
Letitroll98
hooking up Little Dot Amp to Dodd Tube Buffer
0 Members and 1 Guest are viewing this topic. Read 1340 times.
sugbob21
14 Jun 2013, 03:32 pm »
the Dodd Tube Buffer has 2 RCA outputs and 1 RCA rec out . Is it possible to hook up my Little Dot Heaphone amp to the tube buffer through any of these outputs ? i am not sure if it will mute the speakers at all.
Noseyears
Restricted
SS-Audio
Re: hooking up Little Dot Amp to Dodd Tube Buffer
18 Jun 2013, 07:42 pm »
I think the most logical way is to go from the audio source to the buffer, then use the buffer output to the headamp.
eclein
Volunteer
..we walk the plank with our eyes wide open!-Gotye
Reply #2 on:
19 Jun 2013, 03:42 pm »
2nd that!! Its the way I ran mine and it worked fine. It never blew up or anything....lol
sugbob21
Reply #3 on:
19 Jun 2013, 04:36 pm »
thats exactly what i am always afraid of. thanks for the info.
eclein
Volunteer
Reply #4 on:
20 Jun 2013, 03:33 pm »
myself included sugbob21, I used to start every question I had with "will I blow anything up..". Even now I always test for excess heat all the time. Your not alone in that!!
Noseyears
Restricted
SS-Audio
Reply #5 on:
20 Jun 2013, 05:30 pm »
Quote from: eclein on 19 Jun 2013, 03:42 pm
Well, thanks for confirming that Ed
Headphone Mania
Letitroll98
