Nordost Blue Heaven Speaker Wire 10 Feet pair Biwire with Z Banana Plugs
0 Members and 1 Guest are viewing this topic. Read 780 times.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
One of the audio classics in terms of speaker wire. Often considered the sweet spot of the Nordost line up, not as expensive as Red Dawn but offering the lions share of the benefits. This is not your Grandpa's speaker wire! Very transparent and detailed, with no obvious colourations.
Terminations are the Z banana plugs on both ends. This set has biwire terminations on one end. Banana plugs are in excellent shape.
Ribbon speaker wire usually gets light creases in them due the nature of their design. Hard creases can compromise the internal wire, as due cuts of course, but that is not the case with these. There are some irregularities to the insulation which are light creases due to how the wire gets laid out behind the system. But this is cosmetic only, and does not affect its performance.
Originally $600 for 10 feet pair plus an extra $75 for the extra terminations
This pair $225
