FS: USB Slim Microscope 0.3 MP 1-200x Magnification with Adjustment Stand - $50
0 Members and 1 Guest are viewing this topic. Read 537 times.
lakeallen
FS: A nice USB microscope with metal adjustable stand, lens attachments and software. Load the included software on your computer then plug it into a USB port and your viewing. Has a built in light and also takes nice, clear pictures that are saved onto you computer. Works great with no signs of wear, used infrequently during the year I owned it. Purchased from Parts Express (part #360-512)for $82 dollars. Works great for turntable/cartridge alignment for you audiophiles or any other project requiring precise magnification and adjustability.
 From the Parts Express website:
 Specifications:
• Camera: 0.3 mega-pixel CMOS sensor
• Image resolution: 640 x 480
• Image format: BMP
• Video resolution: 640 x 480
• Video format: AVI
• Frame rate: 30 FPS (@ VGA resolution)
• Magnification: Adjustable from 1x to 200x
• Focal range: 10 mm to infinity
• PC interface: High-speed USB 2.0
• USB cable length: 6.7 ft.
• Compatible with Windows XP/Vista/7
• Microscope dimensions: 0.47" dia. x 5.5" L.
