damping factor
0 Members and 1 Guest are viewing this topic. Read 2180 times.
G Georgopoulos
damping factor
« on: 8 Jun 2013, 02:06 am »
Hi a friend of mine told me the damping factor is reduced by the cable resistance.is this the case what do you think?
the way i see it is
damping factor = Rload + Rcable / zout
the above formula actually increases the damping factor!!
but because the Rcable is not Rload of the voice coil it cancels itself
so
we have now damping factor= Rload / zout
which is not reduced as my friend told me
what do you think??
*Scotty*
Re: damping factor
« Reply #1 on: 8 Jun 2013, 02:20 am »
A simple test could be done by inserting a 0.3 ohm 30watt resistor inline between the power amp and the loudspeaker, you could scale the resistor up to 1ohm and see what you hear if the results of the 0.3ohm resistor test were inconclusive.
Scotty
Davey
Re: damping factor
« Reply #2 on: 8 Jun 2013, 03:53 am »
Your friend is correct.
Damping factor is equal to Zload / (Zout + Rvc)
Zload being the driver nominal impedance.
Zout being the amplifier output impedance.
Rvc being the DC resistance of the voice coil.
Cable (series) resistance adds to the denominator of the calculation so it will reduce the damping factor.
Dave.
G Georgopoulos
Re: damping factor
« Reply #3 on: 8 Jun 2013, 05:39 am »
Dave.
Zout is internal impedance of the amplifier,how come you add to it the Rvc of the voice coil??...
your calculation ie with an Rvc of 4ohms and Rload of 8ohms will produce a damping factor of 2 unreal!!! :green:
Davey
Re: damping factor
« Reply #4 on: 8 Jun 2013, 09:53 am »
Rvc and Zout (and also cable resistance) appear as series elements in the analysis.
Yes, a driver with a nominal 8 ohm load and Rvc of 4 ohms would yield a damping factor of 2.
This might not be the definition of damping factor you're used to seeing in specs.  Many times amplifier manufacturers just make a simple calculation of 8 ohms divided by Zout.  The number is higher in that case, but it's still the same configuration.
Regardless of the calculation used, adding cable resistance reduces damping factor.  If you think about it intuitively you'll realize that must be the case.
Dave.
Speedskater
  • Kevin
Re: damping factor
« Reply #5 on: 2 Jul 2013, 01:34 pm »
For completeness three good Dick Pierce papers on the subject:
'Damping Factor: Effects On System Response'
by Dick Pierce
http://www.audioholics.com/education/amplifier-technology/damping-factor-effects-on-system-response
different edition
Dick Pierce
Professional Audio Development
http://www.cartchunk.org/audiotopics/DampingFactor.pdf
'Damping: Loudspeakers In Series'
Dick Pierce
Hanover, MA
“Debunking audio myths for over a fiftieth of a millennium”
http://www.cartchunk.org/audiotopics/SeriesSpeaker.pdf
Dick Pierce - Audio Topics
