0 Members and 1 Guest are viewing this topic. Read 3669 times.
CUJOBOB: OK, Thanks for inform.Worth mention the HE400 is minijack connector and 92,5dB sensitivity and can be driven by any CD Player or PC output as too a regular phone amp.And otherwise the HE500 being a low sensitivity 89dB phone, need the usual special hi voltage electrostatic amp.
I'll strongly consider that.
I would consider trying a different amp than the O2.Just my 2 cents.I have a Lyr for my HE500's, but they are supposed to be much harder to drive (as noted in this thread).Randy
If you're around LA, I have a couple amps sitting around collecting dust.
i just upgraded from Audioengine to O2 amp...and the change was there...what you recomend...V
How do you like the O2 amp so far?
