SST2's caps and transformers
0 Members and 1 Guest are viewing this topic. Read 998 times.
drummermitchell
« on: 5 Jun 2013, 10:52 pm »
Q for James,James can't ALL SST-2's like the 4,7,14 and 28's have the new caps and transformers installed if not installed already.
Shipped my 28s out today but someone said depends on the age of them and that I probably had the new caps and transformers,which I tried to explain that I had got these way before there was any talk of the new caps or transformers.
The date code is 7/15/07 and the serial #000126,000127
Thoughts,thx.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SST2's caps and transformers
« Reply #1 on: 5 Jun 2013, 11:02 pm »
Thoughts,thx.
It will depend on the age of the chassis as to whether the new transformers which are larger will fit.
James
drummermitchell
« Reply #2 on: 5 Jun 2013, 11:18 pm »
Ok,thx,i'll ph Mike and see if these are new enough.
