SOLD!!!!!Von Schweikert LCR-15 in cherry! Only $500! Excellent condition!!
0 Members and 1 Guest are viewing this topic. Read 1044 times.
Malbec Man
As part of my VS system upgrade, I am selling off my speakers  Not to worry, I'm upgrading within the VS lineup!  Please see my other listings for the rest of the 5.1 system.
Perfect match for the VR-2s (also for sale :thumb:).  Here is the technical info from the VS website:
SYSTEM TYPE: Shielded three-way full range dialogue/general purpose speaker system. One woofer is used for bass only, while the second woofer is used for midbass and midrange frequencies. Can be mounted horizontally or vertically.
BASS LOADING: Aperiodic Pressure Release design using 100% stuffing density. Note that the vents are not bass reflex ports, but act as pressure release orifices. Can be placed inside a cabinet.
BASS DRIVERS: 2pc --5.5" heavy- duty bass/mids with cast frame, cellulose acetate pulp cones impregnated with mica substrate and damped with a carbon fiber/resin polymer, Low Distortion Motor system, butyl rubber surrounds, long throw spider, high temperature voice coil and magnetic shielding. This new driver design has a very natural sound quality with inaudible coloration or distortion.
TWEETER: 1" - composite silk/polymer resin dome with Ferrofluid liquid cooling, high temperature voice coil, Low Distortion Motor design, and magnetic shielding. This tweeter is very musical, without harshness, even at high volume levels that would cause "standard" tweeters to fail.
CROSSOVER: Global Axis Integration Network (synthesized steep-filters with phase-consistent behavior) with 300 Hz and 2.2 kHz crossover points. This crossover design has been engineered to radiate sound in a wide "bubble" instead of a "beam," so that phase and frequency response does not radically change off-axis. The finest parts have been hand selected, including polypropylene capacitors and premium air core inductors.
BINDING POSTS: High quality "audiophile" five-way binding posts with rhodium plating.
FREQUENCY RESPONSE: Baffled mounting (inside equipment cabinet): 32 Hz-20 kHz; (free air: 60 Hz-20 kHz +/- 2dB).
SENSITIVITY: 88 dB @ one watt/one meter anechoic, 91 dB measured in room with boundary gain.
POWER HANDLING: 8 watts min., 200 watts peak.
IMPEDANCE: 8 ohms nominal (7 ohm minimum, 19 ohms maximum). SET friendly!
WARRANTY: Ten years parts and labor, excluding abuse such as burnt voice coils.
WEIGHT: 28 lbs packed for shipping, 20 lbs raw.
DIMENSIONS: 17.5" Wide x 10.25" Deep x 7.5" High (horizontally placed).
This speaker was $800 when new and has been lovingly cared for in a smoke/pet/child free home.  I'm offering at $500.  There is a minor blemish on the right top, but invisible from normal position and very small up close.  I tried to highlight it in the picture with a flashlight so there would be no surprises.  The original grill cloth is tear/snag free.  Rated at 8/10 on AGon scale.  Please email me with any questions/concerns, I'm an honest guy who wants to find his LCR-15 a good home.
Thanks for looking!
« Last Edit: 12 Jun 2013, 10:41 pm by Malbec Man »
azhtnut
Am willing to offer $300 for this speaker including shipping.
Marty
