0 Members and 1 Guest are viewing this topic. Read 6703 times.
Please post what's in the rest of your system....amp / speakersAre you looking for tube or SS preamp ?How much do you want to spend for a Cd player...or maybe a computer setup ?
Hello. I am looking at getting rid of my Audio Research LS-7 and try another Pre-Amp. I am wondering if anyone has suggestions on great pre-amps with a better sound stage than my Audio Research? Thanks in advance for your help! I am also considering upgrading my Ikon MKii cd player. Any suggestion on cd-players? Thank you- Justin
The Sony SCD-XA5400ES is a very good one box cd player. The Rega Apollo is another good one. I have an older Sony XA20ES running into a Schiit Audio Bifrost DAC. The fixed laser lens of the Sony makes it a good transport.
The best thing is to go the PC / standalone DAC route for sound quality and cost. There maybe a bit more initial set up involved, but it will be way worth it in the end.
Do you know if there is a way to control the music on an ipad if you go this route? Do you have any pics of what this setup would look like?
