0 Members and 1 Guest are viewing this topic. Read 17651 times.
fe167e version
Hi Johnaki and all Audio Circle members.Can this help?http://frugal-horn.com/metronome-table.htmlGuy 13
Hi John,I would stick with plywood rather then solid lumber. There is a risk of splitting with solid lumber.I wouldn't put the FE126en in a Met. Not a good choice of driver for an MLTL. I think you would do much better using the FF125wk. Look at Dave's reference to find a Met using FF125wk-- IIRC, it was by AmedeusMozart.Cheers, Jim
FE165wk would be a good choice.... The chart have the numbers for that driver.
http://www.diyaudio.com/forums/full-range/85410-metronome-88.html#post2708879http://www.diyaudio.com/forums/full-range/85410-metronome-96.html#post2898754I wouls suggest plywood for the 1st build (just like cookies you won't be able to stop at 1 )dave
Dave,Looks like you have a better memory for what I've done than I do! John,Looks like you're good to go. Keep us poster on you progress!Cheers, Jim
Hi Johnaki and all Audio Circle members.I did a quick search on Google for Spalted Sycamore.Wow that wood is really nice, if it was me, I would gor for that kind of wood and it would make your metronome enclosure one of a kind, unique and awesome...I hope I will see some good high quality pictures of that project.Guy 13
