MPaD and Cover Art
0 Members and 1 Guest are viewing this topic. Read 2102 times.
Samurai7595
MPaD and Cover Art
« on: 2 Jun 2013, 01:38 pm »
I'm using MPaD on my iPad Mini and I have several albums that do not display the album cover (cover art).
Even when I try to use the Wizard within MPaD, it does not pick-up the album cover however, when I look in the folder, there is a Folder.jpg file.
Is there a way to paste an album cover in MPaD using Safari (Internet) on the iPad?
unincognito
    • bryston.com
Re: MPaD and Cover Art
« Reply #1 on: 5 Jun 2013, 02:01 am »
Hello,
If you go into mPad, click the "target" button in the top middle of the app.  Click advance and scroll down to local cover art section and URL should be "http://<BDP's IP address>/music" and the file name should be "Folder.jpg".
Chris
Alpha10
« Reply #2 on: 5 Jun 2013, 07:54 pm »
Since the last MPad update I cannot get this to work either, even doing the above.
Cheers
Samurai7595
« Reply #3 on: 5 Jun 2013, 11:59 pm »
It worked for me, thanks unincognito!  :thumb:
As long as each album has a Folder.jpg file in it, providing the URL will pickup the Album Art within the folder structure (at least for me it did).   :D
unincognito
    • bryston.com
« Reply #4 on: 6 Jun 2013, 02:13 am »
Cheers
Have you tried uninstalling and reinstalling mPad?
Chris
Alpha10
« Reply #5 on: 20 Jun 2013, 07:47 am »
Chris
Thanks Chris, I did a full clear cache, delete, re-install and it is working really well again.
Cheers
Robert D
« Reply #6 on: 31 Jan 2014, 09:05 pm »
Hello,
Chris
Help Needed !
How is this supposed to be typed out in the URL of Album Art on Mpad
192.168.2.15/music.folder.jpg
Robert
like below ???
http://192.168.2.15/music.Folder.jpg.
Robert D
« Reply #7 on: 31 Jan 2014, 10:00 pm »
Cheers
Chris
Thank you Sir
Up at 100%
Regards Robert
