0 Members and 1 Guest are viewing this topic. Read 4974 times.
I have a similar living room size / arrangement and am quite happy with my REL T-5. It's a sealed 8', very fast & tight, but still has decent enough slam and volume for home theater in a smaller room like that. They go for $700, but I bought a demo from MD at some point for 20% off. http://www.musicdirect.com/p-13261-rel-t-5-subwoofer.aspxMine is a glossy white and I think it looks great w/ my cherry Totem Arros not to dissimilar to your Songtowers. Very high WAF : being that they blend w/ the wall, but being glossy and very nicely made, you can admire them as well. Even my EX-wife admires them! E-WAF more impressive still than WAF?If you want something even tighter / higher end with even deeper bass, then the REL "R" series (higher end 10' sealed w/ better cabinet + class d amp), is the next step up. The current R218 is just within your top budget @ $1300 new.http://www.musicdirect.com/p-38017-rel-r-218-subwoofer.aspxBoth the T-5 + R218 are Absolute Sound winners.You can also opt to look for a used R205, which is largely the same as the R218 & can be had for half the price of the R218 new (which means you can get two!). There are advantages to running dual subs, but if I were you I'd start w/ one good one. Unless you're really looking to do the "boom" it seems to me that an 8' sub is enough for that size room. I think the quickness advantage of the 8' for music, particularly if that your primary use, outweighs the absolute lack of low end of a bigger coned sub.
I'm usually so with you, but "smaller room like this"? And comparing Arro with SongTowers? Better check your magnification factor my friend.
