Question On Accessing Music Using BDP-2 In Local Mode
0 Members and 1 Guest are viewing this topic. Read 900 times.
parisphoto
Here's my question.
To access music files using the BDP-2 in Local Mode, that is, not connected to a network, am I correct that you must drill down your directory tree via the front display ?
My music is stored in a parent folder named MUSIC.
Under MUSIC are folders named BEATLES, COWBOY JUNKIES, DOORS, etc.
Under the Folder of the Artist's Name are separate folders for each album.
Each Album Folder contains all the songs for that album.
Am I correct that if I want to listen to "Here Comes The Sun", I must click on MUSIC,- BEATLES,- ABBEY ROAD, -Here Comes The Sun, using the front display to see what I'm doing.
Exactly as if I were using the Directory Tree in Windows Explorer.
Thanks.
unincognito
    • bryston.com
Re: Question On Accessing Music Using BDP-2 In Local Mode
« Reply #1 on: 28 May 2013, 01:51 am »
Yup, not ideal for large music collection; you may wish to invest in some method of connecting your BDP to your home network.  Whether that be running a network cable, using a powerline av kit or a wireless bridge.
Chris
parisphoto
« Reply #2 on: 31 May 2013, 12:49 am »
Thanks.
That's what I was afraid of..................................... .
