Planet 10 uFonken Fostex FF85WKen
0 Members and 1 Guest are viewing this topic. Read 3289 times.
jparkhur
« on: 26 May 2013, 06:45 pm »
Finally got around to finishing these for my littles bedroom.  I need to break then in some. Right off the play the sound stage is deep, imaging is spit on, depth of stage is there too.  They may get to a 100 F3, maybe lower.  Dave can tell us if he measured it. I will paint the vents later.  Hand wiped Minwax green dye with a semi gloss oil bases clear.
Dodd SGPreamp
3 Watt EL 84 amp
MacMini
Pi Audio Battery Buss and B Buss
Jon
jparkhur
Re: Planet 10 uFonken Fostex FF85WKen
« Reply #1 on: 26 May 2013, 06:52 pm »
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #2 on: 27 May 2013, 08:12 pm »
That is about right.
dave
