Mpad/mpod volume control
0 Members and 1 Guest are viewing this topic. Read 1347 times.
Gaustabl
« on: 26 May 2013, 05:37 am »
Hello.
Doen anyone here know how to configure the volume control in the mpod/mpad softare for the bdp-1. The amp i am using is an electrocompaniet, and using this together with the Naim nd5 xs i am able to control it via the ir out. There is no such thing on the bryston, but maybe via some rs232 to ir hardware ???
Best regards Lars
skunark
Re: Mpad/mpod volume control
« Reply #1 on: 27 May 2013, 02:43 am »
The BDP-1 isn't configured to use the MPD software volume control.   If the right libraries are installed it's probably something you can tweak with the scripts page, but guessing that's not what you are after.
unincognito
    • bryston.com
« Reply #2 on: 28 May 2013, 02:09 am »
Hello,
Volume should be adjusted via your preamp for best results.
Chris
Gaustabl
« Reply #3 on: 28 Apr 2014, 11:37 am »
 :D
I got it to work, changed mixer according to this;
Changing Mixer Type
MuBox by defaults set mixer_type to "hardware". MPD supports 3 types of mixers. See below for description. For best sound quality, set mixer_type to "disabled". Setting to "software" is not recommended unless it is really necessary to control volume for your use, e.g. listen via headphone/earphone, and your DAC does not have hardware volume mixer built-in.
# Volume control mixer ########################################################
# These are the global volume control settings. By default, this setting will
# be detected to the available audio output device, with preference going to
# hardware mixing. Hardware and software mixers for individual audio_output
# sections cannot yet be mixed.
# An example for controlling an ALSA, OSS or Pulseaudio mixer; If this
# setting is used other sound applications will be affected by the volume
# being controlled by MPD.
#mixer_type                     "hardware"
# An example for controlling all mixers through software. This will control
# all controls, even if the mixer is not supported by the device and will not
# affect any other sound producing applications.
#mixer_type                     "software"
# This example will not allow MPD to touch the mixer at all and will disable
# all volume controls.
#mixer_type                     "disabled"
Have not yet tested how it impacts on the sound quality though.....
best regards Lars
