tried and tested dimensions for H frame alpha 15
0 Members and 1 Guest are viewing this topic. Read 2793 times.
versus rider
« on: 22 May 2013, 07:27 am »
As the title, does anyone have dimensions of their H frame for Eminence Alpha that has stood the test of time and gives pleasing bass. I need to reduce the height of my speakers, at present the bass section is about 660mm tall, combined with a 200Hz tractrix horn they are over 1 metre. I know that an H frame will be around 440mm high and so combined with the horn I cannot get shorter than around 1 metre. But I am thinking to site the H frames to the inside of the horns and mount the horns on a stand.
MJK
    • Quarter Wavelength Loudspeaker Design
Re: tried and tested dimensions for H frame alpha 15
« Reply #1 on: 22 May 2013, 09:59 pm »
The H frame dimensions and crossover settings given in this article
http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf
have been used my quite a few DIYers and the reports have generally been positive. The design was provided in 2008 so I guess one could say it has stood the test of time.
versus rider
« Reply #2 on: 23 May 2013, 05:11 pm »
thanks for that, I had seen that article but not read it through. He talks of a cut off at 200Hz and that increase the length of the frame would result in a peaking response around the cut off. It says nothing that I can see about reducing the length, I have calculated the length based on a cut off at 350Hz ( I run my alphas up to 350Hz with the help of frame bracing ) at 226mm long. Would this have some other effect.
MJK
« Reply #3 on: 23 May 2013, 06:20 pm »
Reducing the length allows you to run the H frame higher in frequency but at the cost of some low end extension. The shorter H frame will not go as low in frequency (probably less than 5 Hz difference) and will be a little more efficient. The low end curve of the shorter design will be between the H frame and OB SPL responses in the article. It is all trade-offs.
