0 Members and 1 Guest are viewing this topic. Read 43208 times.
Does depend on if the amp can handle the KT120s. Think it depends on the transformers mostly. I really like my Rogue Stereo 90 with the KT-120s.
I have a ARC VS-110 and I called Audio Research and s/w Kal and he recommended 6550's and modern ones as the old or NOS ones dissipate only 35 watts whereas the new production 42 and they were designed with that in mind. He said that I could go with KT88' and even KT120's, but would lose some speed and dynamics....it would be a very warm tube sound....I opted for 6550's and couldn't be more pleased. Jim
The ARC VS115 sounds like an amp I want to try...I have tried a ARC classic 60 and sounded great...plenty of power.
Forgot about Rogue...How would you describe the sound of Rogue amps as opposed to ARC or Quicksilver..anyone have any input ??
Don't forget the Music Reference RM-200!
I've thought about this in considering buying an older Conrad Johnson MV751A1 from my tube tech that uses 6550s & was curious about running KT120's on it. He seemed to feel there was no problem using KT120's. To get the full power of the KT120's the B+ voltage (?) would have to be raised. Aside from how they sound, another reason I've heard that KT120's are preferable is longevity - i.e. whereas depending on the design a 6550 or KT88 tune in amp may be run close to flat out (e.g. a Mcintosh MC275), a KT120 has more power handling so you don't have to run them as "hot" to their max potential to get the same output.Anyway - talking here a bit beyond my personal knowledge, but just passing along what folks more knowledgeable than I have told me.........
Sometimes what seemed a good idea.... in the cold light of reality and reason sometimes loses its appeal.I wanted to try the KT120's due to their robust reputation, higher power output, sonics ( yet to be heard), longevity and similar price.But I am finding out their application may be more limited than I wanted.My two ultimate criteria for a tube amp are sonics and price. If this amp can use KT120's great, if not the standard output tube will do just fine. Thanks for every ones input....Greg
The Rogue amps will take KT120s without any problems. I've owned a CJ MV60SE and Quicksilver Mono 100s, and had a CJ LP66, McIntosh MC275 V5, Music Reference RM200, and VAC PA100/100 in my system and overall I'm more happy with my Rogue Cronus Magnum with the KT120s. I'd lend it to you but it's already been shipped to my soon to be new home in FL.
