SOLD : ACURUS 200X3 3 channel Amp - $350 OBO
0 Members and 1 Guest are viewing this topic. Read 2752 times.
jarcher
  • It Just Sounds Right
« on: 17 May 2013, 03:16 am »
Yes, the name says it all : 200WPC into 3 channels (at 8ohms : 300WPC into 4 ohms).
If you're looking at this, you probably know something about Acurus / Aragon of former Mondial Designs (now reborn by Indy Labs).  Simple robust Mil-spec build with no fancy cosmetics: glass epoxy boards, heavy torroidal transformers, thick steel chassis, all US made.  The 200WPC is likely understated.  This amp has all the power to drive the hungriest most inefficient speakers.
I eventually moved on to a 7 channel Krell amp, but kept this around out of nostalgia, but it's time to move on.
I think the original retail was like $1500, but I'm asking $350, which is the current average on Ebay.  I'll also consider interesting trades.  Nothing specific in mind, but currently into tube gear.
I prefer paypal as personal / gift for speed & for no commission, but will accept other forms of payment.
I don't have the original box (or manual) but will be carefully packed & can be sent USPS, UPS, Fedex (preferred).  Shipping weight is somewhere between 35-40lbs.
In 8/10 cosmetic condition : a few minor scratches along the top edge of the face plate.
Any other questions, please feel free to ask.
Detailed specs:
Specifications :
Rated Power(200 watts)...................Continuous into 8 ohms, 20Hz to 20kHz,
                                   ...................0.005% intermodulation distortion
                                   ...................No more than 0.06% total harmonic distortion
Rated Power(300 watts)...................Continuous into 4 ohms, 20Hz to 20kHz
                                  ....................No more than 0.03% total harmonic distortion
Signal-to-Noise Ratio.......................110dB "A-weighted"
Power Consumption........................1,200 watts, all three channels driven at rated power
Quiescent Power Consumption.........75 watts, all three channels with no signal
Input Sensitivity............................ ...1.1V for full rated power
Input Impedance.............................. 20k ohms
Frequency Response.......................20Hz to 20kHz, +/- 0.1dB
                                ......................10Hz to 100kHz, +/- 0.5dB
                                ......................1Hz to 130kHz, +/- 0.1dB
Channel Separation..........................90d B
Damping Factor................................8 ohms, 50Hz: 500
Dimensions(w x d x h)......................48.5 x 35.5 x 16 cm
Weight................................. ...........15kg (33lbs)
« Last Edit: 27 May 2013, 02:42 am by jarcher »
