SOLD - Marantz 4001 Receiver : NOW Only $175
0 Members and 1 Guest are viewing this topic. Read 1397 times.
jarcher
  • It Just Sounds Right
« on: 17 May 2013, 01:09 am »
More spring cleaning : this receiver has gone unused the last two years as it was replaced w/ a SR5005 + an AV7005.
It has that warmer & musical sound that Marantz's are known for, not your typical shrill mass market receiver. So it's good for both music & home theater.
It's rated at 80WPC into 8ohms & 105WPC into 6ohms. I tried it recently w/ some Vandersteen 2CE that are 7 ohm nominal & 4 ohm minimum w/ a lowish 86db efficiency rating, and it had no problem driving it.
What are you NOT getting that a 2013 receiver might have?  Mainly it doesn't do Dolby TruHD & DTS HD Master Audio, which is a newer hi rez format mainly just for blu ray players.  If you're going to use it for DVD players, satellite / cable boxes, or even apple tvs, etc, theses are typically plain dolby digital, which this does support.  This receiver does have 8 ch in, so if you're blu ray player has analog out & these hi rez formats, your good to go. See my other listing for a Pioneer Elite blu ray w/ analog audio output if interested.
The other main omission is automated room correction software (e.g. Audessy), which some people swear by, others not so much.  And lastly, networkability / apple airplay / etc.
What it does have that is less common these days is 8 ch pre-amp output, so you're free to use whatever external amplification you want & use this as a budget home theater processor.
Shipping weight is about 30lbs.  Can send it USPS, UPS, or Fedex (preferred).  Buyer pays shipping.  Guaranteed not to be DOA, but otherwise all sales final.
Comes with original remote, manual, FM + AM antennae.  I don't have the original box, but will be carefully packed.
Any questions, please feel free to ask.
Detailed Specs:
• 80 watts (into 8 ohms) x 7 ch Amps• HDMI (V1.1) Repeating: 2-In / 1-Out• All discrete amplifier stages• x3 Assignable Components Inputs• 32 bit DSP• 192 kHz/24-bit D/A converters for all channels• Dolby Digital EX, Pro Logic IIx (Movie/Music/Game),• DTS 96/24, ES (Discrete 6.1/Matrix6.1),Neo:6 (Cinema/Music)• SRS Circle surround II (Cinema/Music/Mono)• Dolby Headphone• Pure Direct mode• On Screen Display®/DTS ES®SURROUND RECEIVER• Component video switching (3 in/ 1 out)• x3 Optical / x2 Coaxial digital inputs (4 assignable)• 2nd Zone Audio Output (Same Source)• 50 AM/FM station presets• Improved Station naming• Simple setup menu• Display dimmer• D-BUS (RC-5 In/Out)• Direct IR Flasher Input remote connection• Detachable power cord• Front panel A/V/Optical inputs• Learning Backlight system remote•
« Last Edit: 18 Jun 2013, 02:36 am by jarcher »
jarcher
Re: Marantz 4001 Receiver Only $199
« Reply #1 on: 17 May 2013, 05:26 am »
Might also consider interesting trades.  E.g. some cheap & cheerful chinese audiophile thingy such as USB DAC / headphone amp / etc particularly if there's a tube in their somewhere. Open to ideas.
jarcher
« Reply #2 on: 24 May 2013, 09:17 pm »
Still available. Will consider reasonable offers and interesting trades as well.
jarcher
Re: Marantz 4001 Receiver NOW Only $175
« Reply #3 on: 1 Jun 2013, 06:59 pm »
Asking price now reduced to $175!  Can't do better for that price! Now will also go on Audiomart + Craigslist, so act fast.
raysracing
Re: Marantz 4001 Receiver : NOW Only $175
« Reply #4 on: 1 Jun 2013, 10:12 pm »
I'll et back to you on this tonight, but good luck if it sells before then. Off to date night with wife (no kid).
raysracing
« Reply #5 on: 8 Jun 2013, 12:57 am »
One thing I have is a really good condition and working Grant Tube Buffer.
jarcher
« Reply #6 on: 8 Jun 2013, 05:30 pm »
Still available - still a great deal! For most you can get it delivered to your door for under $200!
jarcher
Re: SOLD - Marantz 4001 Receiver : NOW Only $175
« Reply #7 on: 18 Jun 2013, 02:36 am »
SOLD!
