NEW PRODUCTION
0 Members and 1 Guest are viewing this topic. Read 26455 times.
watercourse
Re: NEW PRODUCTION
« Reply #80 on: 27 Sep 2013, 04:25 am »
Hmm, fine tune, don't fine tune, center, don't center, azimuth drifts over time, rather, it corrects itself over time... ?
There does not appear to be consensus at all.
We shall find our own way, and it will be good.
SteevA
Re: NEW PRODUCTION
« Reply #81 on: 27 Sep 2013, 09:27 pm »
"As long as the golf ball does not touch the sides of the cup it does not matter if it is a bit off centre"
i think it is depend what cartridge you use ,it means 'FINE TUNE',is it right???
 :D
Sam
I was really only referring to maintaining azimuth.  Moving the ball about in the cup will obviously effect other aspects of cartridge alignment.
gagamut
Re: NEW PRODUCTION
« Reply #82 on: 28 Sep 2013, 04:22 am »
So i ask 'is it right'??and ,my setup,the golf ball is center of the cup(i use Lyra cart), :D
Sam
SteevA
Re: NEW PRODUCTION
« Reply #83 on: 28 Sep 2013, 04:28 am »
Sam
You have to assume it was designed for the ball to be in the centre of the cup and so putting it there would be 'right'
But it wont hurt to move it round a little and decide for youself.
gagamut
Re: NEW PRODUCTION
« Reply #84 on: 28 Sep 2013, 04:40 am »
Sam
one more thing,we can make a conclusion if everybody setup the golf ball is center of the cup(of course from outer groove to inner groove no distortion),so what Cartridge you use?? :D
Sam
SteevA
Re: NEW PRODUCTION
« Reply #85 on: 28 Sep 2013, 05:09 am »
Currently centre and using a DV Te Kaitora Rua. No distortion and ball stays in the middle.
rob400
  • Versalex and Audio Note for the rest
Re: NEW PRODUCTION
« Reply #86 on: 28 Sep 2013, 06:28 am »
As there isn't any overhang adjustment possible where the cartridge bolts onto the arm I feel its logical to centre the golf ball in the cup. I use a DV cartridge also and this is the range that WTL recommend. My cartridge tracks very well so unless your cartridge has a very differant design shape keep in Central and enjoy.
gagamut
Re: NEW PRODUCTION
« Reply #87 on: 28 Sep 2013, 09:38 am »
i currently use Lyra Skala,and the ball center of the cup,no distrotion :D
