Question on adding volume control to amp
0 Members and 1 Guest are viewing this topic. Read 2017 times.
mikeeastman
« on: 14 May 2013, 02:57 am »
I have a classD amp that I'm going to power a sub with. The sub has a duel voice coil driver and I'll use one channel to drive each coil. Here is a diagram of how I wired in Alps pot to give mono signal into each channel, as my X-over only output mono.
 As i'm fairly new at this I thought I would check here to make sure this will work, as someone said all the smart guys hang out here   :thumb:  Thanks for any help.
   Mike
Davey
Re: Question on adding volume control to amp
« Reply #1 on: 14 May 2013, 03:19 am »
It's okay except you need to carry the ground connection across both sections....the same as you have done with the + input.
However, you really only need to use one section of the potentiometer to achieve your goal.
Dave.
mgalusha
« Reply #2 on: 14 May 2013, 04:12 am »
As Dave said, you only need one side of the pot and I would suggest this. By paralleling the sides, the impedance will be cut in half and will be harder for the source to drive.
mikeeastman
« Reply #3 on: 14 May 2013, 01:56 pm »
Thanks guys, which of these two diagrams would be the best way?   :scratch:
See, someone was right the smart guys do hang out on this site.   :thumb:
JohnR
« Reply #4 on: 14 May 2013, 02:35 pm »
Per the responses from Dave and Mike, you just need to go to single pot section.
mikeeastman
« Reply #5 on: 14 May 2013, 03:00 pm »
Thanks, but I don't know what that means, is either of the diagrams, 1 or 2 right?
    Mike
mboxler
« Reply #6 on: 14 May 2013, 03:11 pm »
Hey Mike
You want to either use the top row of pins or the bottom row of pins, but not both.  If you have a mono pot, I'd use it instead, as you are wasting half of the stereo pot.
Hope that makes sense.
Mike
Speedskater
  • Kevin
« Reply #7 on: 14 May 2013, 03:12 pm »
You don't want or need a dual control.  Connect all the wires to a single section with no connections to the second section.
mikeeastman
« Reply #8 on: 14 May 2013, 05:06 pm »
I think the old brain got it, each set of three pins is one channel. So this should do it.  :scratch:
Thanks for your help, Mike
mboxler
« Reply #9 on: 14 May 2013, 06:17 pm »
 :thumb:
FYI...the ground pins from each "mono" pot in the case are probably connected to each other internally (you can test with a DMM), so that part really didn't matter (ground is ground).  Looks cleaner, though, if you treat the entire case as two mono pots sharing the same shaft (man, does that ever sound nasty  :o).
Good Luck!
Mike
