BDP-1 dropped IP address
0 Members and 1 Guest are viewing this topic. Read 1614 times.
ronman
« on: 13 May 2013, 03:13 pm »
MAYDAY MAYDAY
Hi
A flash drive was recently plugged into one of my BDP-1's and now I have no remote access into it. The Samsung tablet and iphones no longer see my BDP-1.  The only way I can get any music to play is when I press and select the front panel buttons (but selecting an album at the bottom of a large hard drive is a pure nightmare). When I scroll through the menu on the face of the BDP-1 I no longer see the IP address like I used to.   Thought it may have been a modem fault, swapped it for another netgear model, same fault.
Any help or suggestions would be greatly appreciated
Thank you
Ronald
unincognito
    • bryston.com
Re: BDP-1 dropped IP address
« Reply #1 on: 13 May 2013, 03:28 pm »
MAYDAY MAYDAY
Hi
Thank you
Ronald
Hi Ronald,
Have you tried resetting the network settings from the front panel controls?  Oh and which version of the firmware are you running?
Chris
ronman
« Reply #2 on: 13 May 2013, 03:32 pm »
Hey Chris
I am still running the original firmware that the BDP-1 came with as the player has never given any issues....if it isn't broken I dont fix it....
I just selected the "factory reset" button on the front panel......the IP address is still not being displayed as it used to, till not access or control via a remote device.
Ronald
unincognito
    • bryston.com
« Reply #3 on: 13 May 2013, 03:41 pm »
How long did it take? a few seconds or three or four minutes?
Chris
ronman
« Reply #4 on: 13 May 2013, 03:55 pm »
it took about 3 maybe 4 minutes to do the reset
firmware version seems to be S1.16  2011.07.15
and there is there another odd number when I press the left arrow button 00:0d:b9:0e:04:00
I used to have an odd number like that and the IP address  (the BDP-1 at home shows both and still runs fine...the above one is here at the office)
Brad
« Reply #5 on: 13 May 2013, 04:22 pm »
That "odd" number is the MAC address of the player
ronman
« Reply #6 on: 13 May 2013, 04:33 pm »
Nice truck there on your profile pic Brad
Ok.....whats involved in doing a firmware update  ( I have never updated a hifi component). I get an update cd once in a while for my  dCS which automatically updates when you play the disc, so please excuse my ignorance.
If a firmware update doesnt work, then I will take the BDP-1 to the store I bought it from and hopefully somewhere along the way this matter can be resolved.
In the meantime...a quick thanks to everyone's input
Mike Pickett
« Reply #7 on: 15 May 2013, 08:12 pm »
Hi Ronald;
If you can't access the unit through the network, you're not going to have much luck updating the firmware...  I can arrange to have a new compact flash card sent out with the latest firmware on it; just send me an e-mail with your shipping address and phone # to [email protected].
This should get you up and running, and running current software.
Mike
ronman
« Reply #8 on: 15 May 2013, 08:40 pm »
Mike !!
You are a legend !!
Thank you !! Will email you shortly
Ronald
