Outlaw 7125 $600
0 Members and 1 Guest are viewing this topic. Read 891 times.
jparkhur
Outlaw 7125 $600
« on: 13 May 2013, 01:09 pm »
Outlaw 7125, original owner, used in theater system that I am upgrading to the more powerful model.  125 watts in to 8 ohms/ 190 in to 4 ohms.  Great amp with no issues. Shipping is a flat 65 dollars fedex, insured.
Power Output: 7 x 125 watts RMS at 8 ohms, all channels driven from 20 Hz to 20kHz with less than 0.05% THD 7 x 190 watts RMS at 4 ohms, all channels driven from 20 Hz to 20kHz with less than 0.05% THD
Signal to Noise: 119dB "A" weighted
Frequency Response: 20Hz. -20kHz. +/- 0.1 dB at rated output
Total Harmonic Distortion: < 0.05% at rated output, all frequencies, 0.01% at 1 kHz.
Intermodulation Distortion: < 0.05% at rated output.
Power Bandwidth: 5 Hz - >125kHz +0/-3 dB
Damping Factor: Greater than 400 from 10 Hz to 400 Hz
Crosstalk: Greater than -90 dB from 20 Hz to 20Khz
Gain: Voltage gain of 28 dB
Slew Rate: 50v/uSec
Input Impedance: Nominal 50k ohms
Input Sensitivity: 1.00 Volts for Full Rated Output
Remote Trigger Voltage: 3 - 32 Volts DC at 5 milliamperes or greater
Dimensions: (HxWxD): 5.9" with feet x 17.2" x 16.2"
Weight: 51 lbs
Power Requirements: 115VAC, +/- 3%, 50Hz - 60 Hz. 1440 watts, maximum
« Last Edit: 14 May 2013, 12:11 pm by jparkhur »
