Need to convert 32 bit 96 K files to 16 bit 48K
0 Members and 1 Guest are viewing this topic. Read 1275 times.
dB Cooper
« on: 11 May 2013, 02:59 pm »
Looking to convert some 32bit 96K audio to 16/48. Amadeus Pro will do the sample rate and XLD will do the bit depth but it annoys me to have to do 2 operations in 2 separate apps. Anything that will do this in one fell swoop? I have access to Logic if that does it.
skunark
Re: Need to convert 32 bit 96 K files to 16 bit 48K
« Reply #1 on: 11 May 2013, 07:25 pm »
Try Max from sbooth.org?
dB Cooper
« Reply #2 on: 12 May 2013, 04:05 am »
I haven't been able to get Max to do anything since sometime in the 10.6 timeframe. It has long been broken on my system and seems to be abandonware.
At the moment I have few enough files that the search is fast approaching taking more time than the two step process so I'll probably just shrug and get on with it. Thinking about the (possible) next time though.
simon wagstaff
« Reply #3 on: 14 May 2013, 11:56 am »
Wow!  where are you getting 32 bit files?  Recording them yourself?
dB Cooper
« Reply #4 on: 15 May 2013, 02:45 am »
Just one file. Never seen 32 bit before and don't expect to again. Friend gave it to me, not sure where the original came from.
