700 Watt/4 ohms-Merrill Audio VERITAS Monoblocks, Hypex Ncore Nc1200 Based.
0 Members and 1 Guest are viewing this topic. Read 2986 times.
ua100k
    • Merrill Audio
MUSICAL * DETAILED * POWERFUL
VERITAS, Roman Goddess of Truth.
The Absolute Sound, Alan Taffel, April 19th 2013
"Although the sound in the Kondo (….) room was very fine, I personally was more taken by Rhapsody’s “middle” room, which was anchored by the amazing, stand-mounted Raidho D-1.1 ($28,500). Are these guys on a roll or what? As driven by a Kondo G70 preamplifier (see how much better that works?) and Merrill Veritas amps, the Raidhos delivered better bass than any speaker this size has a right to. Overall, the sound was sweet and spacious, despite some room-borne mid-bass resonance. BTW, elsewhere in the show, this same amp paired beautifully with Sanders Sound’s new flagship ‘stat, the 10C ($14k). The duo delivered some of the best imaging I heard, along with other virtues, such as transparency, that one expects from good electrostatics."
 - http://www.theabsolutesound.com/articles/new-york-audio-show-the-big-apple-goes-big-time/?page=2
Merrill Audio VERITAS Monoblocks based on the Hypex Ncore NC1200 and SMPS1200 power supply, gives you
  • Large Solid Billet Aluminum Chassis. 17” x 12" x 3” and 35 pounds.
  • Remote Control 12V trigger.
  • Glass Bead Finished for finest ascetics.
  • Stillpoints UltraMini riser footers.
  • Synergistic Research Tunneled Fuse.
  • MA-10 Custom Power Cord from Triode Wire Labs just for the VERITAS Mono Blocks.
  • Cardas Patented speaker binding posts, Rhodium plated on billet copper post.
  • Furutech IEC AC-inlet.
  • Cardas XLR Rhodium over silver plated pins with solid metal gold plated case.
Audio Purity
Merrill Audio’s design philosophy is Audio Purity. Everything is engineered to keep the signal path clean and short. Great attention was paid to removing microphonics that smear the image.
See www.MerrillAudio.net for more information.
For the trade-in program www.MerrillAudio.net/trade-up.html
Specifications
  • 400 Watts into 8 Ohms
  • 700 Watts into 4 Ohms
  • 1,200 Watts into 2 Ohms
  • 2 Mohms Input impedance
  • 0.0004% THD.
  • Balanced differential Input
  • Dual Speaker Binding posts with plenty of room for thick cables.
  • 35 Pounds each Mono Block
  • 17” x 12” x 3” without footers (add 1 inch for footers)
  • 120V or 220V Factory Set.
  • 5 year transferable warranty.
  • Engineered and Handcrafted in the US.
Included:
  • Stillpoints Ultramini Footers
  • Ma-10 Custom designed power cord from Triode Wire labs with 10AWG cables.
  • Synergistic Research Fuse
  • Furutech Gold AC contacts
  • Rhodium plated Speaker terminals
  • Rhodium over silver Balanced input pins.
  • Color on request. NanoCarbon, Bordeaux or Platinum. (4-6 week delivery if not in stock). Platinum Currently in stock.
Review from a VERITAS Owner
http://forum.audiogon.com/cgi-bin/fr.pl?aamps&1365103009&&&/Review:-The-Merrill-Audio-Veritas-Monobl
Take a look at our Trade-up program
http://merrillaudio.net/trade-up.html
$12,000 a pair.
Shipping included.
www.MerrillAudio.net/veritas.html
