stacking toroids
0 Members and 1 Guest are viewing this topic. Read 1932 times.
zachslc
stacking toroids
« on: 12 Jul 2004, 06:46 pm »
Is there any reason I can't stack toroids on top of eachother?  Thanks.
andyr
Re: stacking toroids
« Reply #1 on: 12 Jul 2004, 09:06 pm »
Quote from: zachslc
Yes, their magnetic fields will couple - which is a bad thing.
Andy
AKSA
stacking toroids
« Reply #2 on: 12 Jul 2004, 10:40 pm »
Zach, Andy,
My understanding is that you can stack them, with a five or six millimetre plastic/timber spacer between them, but there's one proviso.
You must not put a completed metallic circuit from the inside right around the outside.  This would create another secondary, with one turn.
So, if you have a very long bolt extending up through the center, it must not be supported at the top with a metallic bracket, as this would complete the circuit with the base attachment.
Hope this helps,
Hugh
