UNISON UNICO TUBES
0 Members and 1 Guest are viewing this topic. Read 1215 times.
jrdcesq
UNISON UNICO TUBES
« on: 12 Jul 2004, 06:29 pm »
Does anyone know what a good tube upgrade for the ECC82/12AU7 input tubes on the unico?  What seem to be the best makers of the tubes?  Are the stock tubes good enough where swapping them wouldn't make a noticable difference?
thanks for you inpuit
aomcm
unico tubes
« Reply #1 on: 9 Aug 2004, 04:52 am »
I tried some cryoed Radiotechniques from ASTI (mid 1960's) vintage.  In my system they had great bass and transparency, but the upper midrange was hard and ultimately too fatiquing.  They might work better in a system that is a little dull at the top end.  I then tried 1950's Longplate Mullards from Brent Jesse Audio.  WOW - these have the magic.  Very smooth and silky.  Very musical.  I love them.  I occassionally miss the great bass from the Radiotechniques, but the Mullards are just so involving - I listen for hours.  I have not heard any other tubes, I love the Mullards and have stopped my tube rolling here.  The 1950s Mullards are expensive, but some of the early 1960s vintage are supposed to be nearly as good.  The readily available ones from the 1980s are supposedly not as good.  Many people also like the telefunken smooth plates and the amperex 7316, if you can find them.  But I would start with some Mullards.  They made a very noticable difference in my system (Vandersteens and Music Hall CD 25).
GerryD
UNISON UNICO TUBES
« Reply #2 on: 10 Aug 2004, 02:39 pm »
I haven't been fortunate enough to hear older Mullards in my Unico, but I'm pleased with the '80's vintage ones I'm currently using.  They are a definite improvement over the stock tubes and are much more affordable.
