0 Members and 1 Guest are viewing this topic. Read 13935 times.
Easy baffle, multiple driver choices, can add subs later. http://www.audiocircle.com/index.php?topic=111297.0Or anything in this grouping, not necessarily this one.. JP
If you want a larger OB type project you could do Hawthorne Audio which has 10" and 15" drivers. They are highly efficient. You could do what Jon is talking about with a bunch of different drivers either full range or coaxial. The coaxial will have a crossover in it. I am kind of intrigued using an Omega 8" driver when Louis starts selling his DIY drivers with 8" servo drivers underneath. You could always use a smaller diameter driver over an 8" driver. For a full range driver the smaller they get the better they are a producing high frequencies, but at the expense of low frequencies. A larger full range driver will be better on the low end, but at the expense of the high end frequencies. Larger diameter full range drivers tend to be more efficient also.
Good thoughts, thanks. I guess it's all about trade-offs. My current speakers use coax drivers, and I like the concept better than full range drivers, which seem to have more limitations. Am I correct in the assumption that the xover in a coax is already integrated into the driver, and thus one less thing to deal with?
There are a bunch of options. You can just get the waveguide and the drivers and build your own box. If you buy the fiberglass WG, you can get it in any color. Maybe use an active crossover,there many combinations. Depends how ambitious you are. There are designs where all you have to do is assemble the kit and you're good to go. Read through the monster thread if you're really interested.
Looks like I'll need sub amplification, but maybe AJ could help me configure the 300w BASH amps in my SAM1s
Gracias, bro. That is indeed a monster thread, it'll take me weeks to get through that thing! I see now that the kit with 15" driver is $400 PER speaker. Man, even a twelve incher would be sick. Get a glossy white fiberglass waveguide, and finish the boxes gloss white. My girl would love 'em.
Hmmm, I could swear they already are. Slave output on unused terminals. Plus I also suggested..wait for it..DIYing a pair of subs for them. For <$400. All in my last email to you (I checked).cheers,AJ
