I need a preamp for my 4BSST2
0 Members and 1 Guest are viewing this topic. Read 16242 times.
bunky
Re: I need a preamp for my 4BSST2
« Reply #60 on: 15 May 2013, 04:59 pm »
You can roll (and replace if necessary) tubes in most any preamp ..... except for the Vincents with soldered-in mini tubes.
That confounds me.
Musical Fidelity used the soldered in mini tubes in the X-10 tube buffer. they were the first tubes that I ever used in a two channel rig and they sounded very good  :thumb:
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #61 on: 15 May 2013, 05:27 pm »
Phone bryston and mcIntosh,It will and does work,,TRIGGER :thumb:
I used the top and bottom of connector,sheild and white wire of the 1/8 stereo cable
Works great,, :D
larevoj
« Reply #62 on: 16 May 2013, 09:22 am »
FYI, I have tried the 4BSST2 with several preamplifier using unbalance and balance. In a Bryston rig there are better synergy in balance connection even when connected with other brands of preamplifier I have the same results.  The BP26 is a tough one to beat and its a bloody fine preamplifier for the money. You will need to fork out real money to beat that and I can assure you will be happy for a long time!
