I need a preamp for my 4BSST2
0 Members and 1 Guest are viewing this topic. Read 16232 times.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« on: 7 May 2013, 08:41 pm »
Have focus audio FS-788
Clearaudio TT and pre
4BSST2
sold my BP-26P
I think it was a mistake,I tried a pass lab,so I sold it,now I need a preamp
BP-26 or ????
avta
Re: I need a preamp for my 4BSST2
« Reply #1 on: 7 May 2013, 08:48 pm »
Shindo Aurieges
turnovertherecord
« Reply #2 on: 7 May 2013, 08:54 pm »
Sure looks like nice stuff  8)
bobNL
  • Some say he's a purist
« Reply #3 on: 7 May 2013, 08:58 pm »
Do you own a decent set of headphones?
BHA-1 could be a nice 2-in-1 deal for you,
Bob
redbook
  • the music is the blood...........
« Reply #4 on: 7 May 2013, 09:05 pm »
I would look for a bp25 . This pre is still surprising me with sonic quality  :thumb: :thumb: :thumb:
Cheeseboy
« Reply #5 on: 7 May 2013, 09:09 pm »
I like the Dodd Audio Battery PreAmp Generation 2.  Three inputs, HT pass through and a remote control.  I just updated the tube to the elusive and holy grail of Russian Supertubes the 6H30DR.  It is more on the detailed but not edged side of things rather than the "Tubey" colored sound.  The tube upgrade added alot of weight.  I mean to say sonic density.  Call Gary and speak to him.   Read the reveiws on the original battery pre.
It is in front of a 380 watt class D amp.  I like tubes in front of solid state.  It might be for you as well.  That Shindo is very nice as well.  The Dodd runs $1500.
What speakers are you using?
Elizabeth
« Reply #6 on: 7 May 2013, 09:53 pm »
I use three preamps with my 4B-SST² amp.
Bryston BP-26
Audio Research Sp-15
VAC Standard
All three are two chassis preamps.
I bought the Bryston new.
The ARC SP-15 was $1,500 three years ago on the gon.
The VAC Standard I paid $1,400 from the gon.
I originally wanted an Audio Research REF3 used for my setup. but i bought the Bryston BP-26.
No regrets.
I use the ARC for the phono stage in it as a second one after my Bryston BP1.5
And the VAC I use as a fancy tube buffer for the digital stuff.
The Sp-15 and VAc are just below the Bryston in quality. And a lot cheaper, used.
If you want some other flavor preamp, i would find a used Audio Research REF3 or LS27
Cheeseboy
« Reply #7 on: 7 May 2013, 10:42 pm »
Sadly the Audio Research LS-27 that was on a-gon this morning is sold.  I would look at an LS-27 a mini REFERENCE 4.
BrysTony
« Reply #8 on: 7 May 2013, 11:00 pm »
I am using an LS-27 with 7BSST2s and I am very pleased with the combination.
Tony
audiogoober
« Reply #9 on: 7 May 2013, 11:05 pm »
A Gill Audio Alana would be great, and a First Sound would be even better...
PRELUDE
« Reply #10 on: 7 May 2013, 11:13 pm »
4BSST2
sold my BP-26P
BP-26 or ????
If you were happy with your BP-26p and want to stay with solid state, why do not get the same one again unless you are tired of it.
Or if you want to go with tube, I have been using my Sonic Frontiers line 2  for over 10 years and I will keep it for sure.
How much would you like to spend for a pre amp?
skunark
« Reply #11 on: 7 May 2013, 11:23 pm »
I use the McIntosh C2300 with my 4BSST2 and can't be happier with it.
Diamond Dog
« Reply #12 on: 8 May 2013, 12:47 am »
http://www.youtube.com/watch?v=AWtCittJyr0
We're on a thread to nowhere....
PRELUDE has a good point ( as he so often does !  :thumb: ): If you long for the lost BP-26, perhaps another one is the ticket. If not, why not ponder what you didn't like about it or would change about it if you could. Then go from there. You flogged it for a reason, no ? What is your quest, good Sir Knight?
D.D.
bjski
« Reply #13 on: 8 May 2013, 02:25 am »
Did you have a hard time finding 6H30 tube? I was wondering if you use NOS tubes or just Sovteck or Eelectro-harmonix? Did you think of trying 6H6P?
werd
« Reply #14 on: 8 May 2013, 02:45 am »
How much gain do you want?
GT Audio Works
« Reply #15 on: 8 May 2013, 11:51 am »
Owning a 4b...I would recommend a tube front end.
Check out one of these...   Dodd..excellent !! ,, spent a lot of time listening to this battery preamp.
                                       Mystere ca21, have been waiting for one of these ,,, on backorder. have high hopes for this one.
                                       Audible Illusions..own one...good match with my 4b...they have a new model out with remote,
                                       word is good on it.
        Greg
turnovertherecord
« Reply #16 on: 8 May 2013, 01:17 pm »
D.D.
The BP-26P,I had was great,I had a listen to a pass lab int 150,so I purchased it,great detail,but no phono,so purchase a clearaudio basic plus to go with the pass lab,great sound but not enough power for my speakers,so I sold it
so now I have a 4bsst2,TT and phono stage,speakers,
do not want tube preamp because of tubes,,do not need gain now because the 4b will have enough power,,,the pass lab had no gain my fault for not understanding what gain is,now I Know
because I only use vinyl,,I was going to get a pass B1 volume control and go direct to the 4b
how would this work???
PRELUDE
« Reply #17 on: 8 May 2013, 02:27 pm »
I Cannot imagine that how many pre amps are out there with phono stage or separate but again Bryston makes phono stage also.
Still you did not say how much would you like to spend and it would help everyone to guide you in the better way.
turnovertherecord
« Reply #18 on: 8 May 2013, 02:32 pm »
The bryston I had had the MM stage built in
pass lab did not
so I purchased the basic plus
my budget is 3k used
can get pre with or without phono
Ron D
« Reply #19 on: 8 May 2013, 02:43 pm »
so you don't want tubes, have had good success (synergy) with a former BP-26, have $3K to spend....
Sounds like a used BP-26 is in the cards for you. One sitting at a dealer in the GTA for $2800 (see Canuckaudiomart) - sounds like the answer to me...
